Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00000.jpg, continuing
Simpler
Post by Simpler »
Running the latest nightly environment from https://github.com/zoneminder-container ... inder-base
nightly-1235
My log file is being filled with the following message (about 40 times per second)
2023/07/25 - 10:13:15	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00002.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:15	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00001.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:15	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00000.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:14	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00002.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:14	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00001.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:14	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00000.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:13	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00002.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:13	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00001.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:13	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00000.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:12	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00000.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:12	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00002.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:12	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00001.jpg, continuing	zm_image.cpp	1184
2023/07/25 - 10:13:11	zms_m2	653	ERR	Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00002.jpg, continuing	zm_image.cpp	1184
Any ideas what could be causing this or how to correct?
Simpler
Re: Couldn't get lock on /zoneminder/tmp/zmswap-m2/zmswap-q341718/zmswap-i00000.jpg, continuing
Post by Simpler »
This is only happening if I'm watching a feed live. For example, with the Montage view up or the Watch view up.
Simpler
Post by Simpler »
This problem started with "nightly-1224" on July 12th with commit bdb0768dfe52034d1e6926fe6c897e6b9b6283b3
and occurs in every nightly after that.
Is this with zmNinja? It has been known to ignore the StreamImageReplayBuffer setting.
You may want to move that path to a tmpfs for performance...
Will do some testing. It seems to be trying multiple times to write that jpeg, but the #'s should be increasing... weird.
Simpler
Post by Simpler »
zmNinja is not installed. Where should I change the directory that it's writing to?
Look into ZM_PATH_SWAP in conf files in /etc/zm/conf.d.
The latest build should fix the Error.
Simpler
Post by Simpler »
Thanks. Yes. It's fixed in last night's build "nightly-1236".
In the docker container: zoneminder-containers/zoneminder-base, I found the ZM_PATH_SWAP variable in the following file:
/zoneminder/defaultconfig/conf.d/01-system-paths.conf/01-system-paths.conf
Checking for tmpfs usage:
# df -k
Filesystem     1K-blocks      Used Available Use% Mounted on
overlay        117839660  68274476  43553132  62% /
tmpfs              65536         0     65536   0% /dev
tmpfs           16377680         0  16377680   0% /sys/fs/cgroup
/dev/sdb       960303848 742517100 168932236  82% /log
/dev/sdd1      117839660  68274476  43553132  62% /etc/letsencrypt
tmpfs             976564     86496    890068   9% /dev/shm
/dev/sda1      492055672 394699180  72334796  85% /etc/nginx/conf.d
tmpfs           16377680         0  16377680   0% /proc/asound
tmpfs           16377680         0  16377680   0% /proc/acpi
tmpfs           16377680         0  16377680   0% /proc/scsi
tmpfs           16377680         0  16377680   0% /sys/firmware
I think I'll let the maintainers of this container handle moving this to a tmpfs as I'm not sure how to automate this.
Thanks again
