Privacy page - re appearing each time console opens
dcung
Post by dcung »
I also posted this on Puppy Linux forum
https://forum.puppylinux.com/viewtopic.php?t=8784
I have used Zoneminder with BusterDog (Debian 10 distro).
I followed these guides/docs to install fresh zoneminder 1.36.x with Bullseye DDog (Debian 11 distro).
https://wiki.zoneminder.com/Debian_11_B ... der_1.36.x
https://zoneminder.readthedocs.io/en/la ... 1-bullseye
It works. But each time I open the console, it presented the Privacy Page again, regardless of whether I accept or decline. Sort of similar to this post, but I was not 'stuck'. I can proceed using zoneminder afterward.
viewtopic.php?t=28398
I tried what was suggested here, but same result, it didn't work - i.e. redo fresh install with edited /usr/share/zoneminder/db/zm_create.sql
viewtopic.php?p=119558#p119558
I was going to try this suggestion (ie, edit the value in DB), but don't know how. Not enough DB skill.
viewtopic.php?p=111151#p111151
Would like to solve this. Any ideas/suggestions please?
Thanks.
Re: Privacy page - re appearing each time console opens
Let's do the db edit thing:
First off, let's see what's in the DB:
mysql -u zmuser -p zm
select Value from Config WHERE Name = 'ZM_SHOW_PRIVACY';
Then let's update it, telling it to NOT show the privacy page
UPDATE Config SET Value = '0' WHERE Name = 'ZM_SHOW_PRIVACY'
dcung
Post by dcung »
I start from scratch again for this troubleshooting exersize.
Still getting privacy page each time console opens.
Looks like value was already 0 ?
I don't know if I'm supposed to do anyting after command above, so I quit MariaDB.
root@live:~# mysql -u zmuser -p zm
Enter password:
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 109
Server version: 10.5.19-MariaDB-0+deb11u2 Debian 11
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [zm]> select Value from Config WHERE Name = 'ZM_SHOW_PRIVACY';
| Value |
| 0     |
1 row in set (0.001 sec)
MariaDB [zm]> UPDATE Config SET Value = '0' WHERE Name = 'ZM_SHOW_PRIVACY';
Query OK, 0 rows affected (0.001 sec)
Rows matched: 1  Changed: 0  Warnings: 0
MariaDB [zm]> \q
Bye
root@live:~#
I also noticed some messages during boot time - see attachment pic.
After each reboot, I have to start zoneminder manually. And it works.
service zoneminder start
dcung
Post by dcung »
I also did this. Made no difference.
Enter password:
Your MariaDB connection id is 42
MariaDB [zm]> UPDATE Config SET Value = '0' WHERE Name = 'ZM_TELEMETRY_DATA';
Query OK, 1 row affected (0.003 sec)
Rows matched: 1  Changed: 1  Warnings: 0
MariaDB [zm]> \q
Bye
root@live:~#
