Login issue
joea
Login issue
Post by joea »
New install. Via the web console, I enabled authentication with the vague thought I should check authorized users first.
I did not and was immediately presented with a login screen. Naturally, none of the user/password combinations I tried are accepted.
Not yet finding a solution that works, which appear to refer to disabling authentication in mysql. I chose the "native" authentication method.
joea
Re: Login issue
Post by joea »
joea wrote: Tue May 02, 2023 6:31 pm New install. Via the web console, I enabled authentication with the vague thought I should check authorized users first.
Seek and ye shall find. Sorted.
burger
Re: Login issue
Post by burger »
fastest way to test streams:
