9:16 camera image = problem?
NotSoWittyName
Post by NotSoWittyName »
Hi, I've meanwhile migrated my 8 Axis cameras from Surveillance Station to ZoneMinder 1.36.31. 7 cams are working fine, one is having problem - in the sense that the camera is rarely recording a frame. What is unique about the camera with problems is that its picture is rotated by 90 degs, i.e. the resolution is 1080 x 1920, not 1920 x 1080.
Log:
"11/19/22, 8:47:37 PM GMT+1",zmc_m8,,1429,INF,"Backyard: 90 - Capturing at 25.06 fps, capturing bandwidth 403742bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:47:36 PM GMT+1",zmc_m8,,1429,INF,"Backyard: 60 - Capturing at 39.05 fps, capturing bandwidth 378898bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:47:35 PM GMT+1",zmc_m8,,1433,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:47:35 PM GMT+1",zmc_m8,,1433,WAR,"non increasing dts, fixing. our dts -3599 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:47:35 PM GMT+1",zmc_m8,,1433,WAR,"non increasing dts, fixing. our dts -7199 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:47:35 PM GMT+1",zmc_m8,,1433,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:47:35 PM GMT+1",zmc_m8,,1433,WAR,"non increasing dts, fixing. our dts -14399 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:47:35 PM GMT+1",zmc_m8,,1433,WAR,"non increasing dts, fixing. our dts -17999 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:47:35 PM GMT+1",zmc_m8,,1433,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:47:35 PM GMT+1",zmc_m8,,1432,INF,"Backyard: 000 - Opened new event 2083, section start",zm_monitor.cpp,1938
"11/19/22, 8:47:35 PM GMT+1",zmc_m8,,1429,INF,"Backyard: 10 - Capturing at 6.16 fps, capturing bandwidth 168236bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:47:33 PM GMT+1",zmc_m8,,1429,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:46:24 PM GMT+1",zmc_m8,,1230,INF,"Backyard: 90 - Capturing at 25.00 fps, capturing bandwidth 499222bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:46:23 PM GMT+1",zmc_m8,,1230,INF,"Backyard: 60 - Capturing at 39.16 fps, capturing bandwidth 444011bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:46:22 PM GMT+1",zmc_m8,,1329,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:46:22 PM GMT+1",zmc_m8,,1329,WAR,"non increasing dts, fixing. our dts -2 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:46:22 PM GMT+1",zmc_m8,,1329,WAR,"non increasing dts, fixing. our dts -3601 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:46:22 PM GMT+1",zmc_m8,,1329,WAR,"non increasing dts, fixing. our dts -7201 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:46:22 PM GMT+1",zmc_m8,,1329,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:46:22 PM GMT+1",zmc_m8,,1329,WAR,"non increasing dts, fixing. our dts -14402 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:46:22 PM GMT+1",zmc_m8,,1329,WAR,"non increasing dts, fixing. our dts -18001 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:46:22 PM GMT+1",zmc_m8,,1329,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:46:22 PM GMT+1",zmc_m8,,1327,INF,"Backyard: 000 - Opened new event 2079, section start",zm_monitor.cpp,1938
"11/19/22, 8:46:22 PM GMT+1",zmc_m8,,1230,INF,"Backyard: 10 - Capturing at 6.24 fps, capturing bandwidth 164947bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:46:20 PM GMT+1",zmc_m8,,1230,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:45:15 PM GMT+1",zmc_m8,,6377,INF,"Backyard: 90 - Capturing at 25.00 fps, capturing bandwidth 380368bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:45:14 PM GMT+1",zmc_m8,,6377,INF,"Backyard: 60 - Capturing at 39.20 fps, capturing bandwidth 392549bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:45:13 PM GMT+1",zmc_m8,,6381,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:45:13 PM GMT+1",zmc_m8,,6381,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:45:13 PM GMT+1",zmc_m8,,6381,WAR,"non increasing dts, fixing. our dts -7201 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:45:13 PM GMT+1",zmc_m8,,6381,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:45:13 PM GMT+1",zmc_m8,,6381,WAR,"non increasing dts, fixing. our dts -14400 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:45:13 PM GMT+1",zmc_m8,,6381,WAR,"non increasing dts, fixing. our dts -18000 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:45:13 PM GMT+1",zmc_m8,,6381,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:45:13 PM GMT+1",zmc_m8,,6380,INF,"Backyard: 000 - Opened new event 2072, section start",zm_monitor.cpp,1938
"11/19/22, 8:45:13 PM GMT+1",zmc_m8,,6377,INF,"Backyard: 10 - Capturing at 6.42 fps, capturing bandwidth 171604bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:45:11 PM GMT+1",zmc_m8,,6377,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:45:05 PM GMT+1",zms_m8,,6344,ERR,"Monitor shm is not connected",zm_stream.cpp,78
"11/19/22, 8:44:55 PM GMT+1",zms_m8,,6300,ERR,"Monitor shm is not connected",zm_stream.cpp,78
"11/19/22, 8:44:04 PM GMT+1",zmc_m8,,6079,INF,"Backyard: 90 - Capturing at 25.02 fps, capturing bandwidth 410374bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:44:03 PM GMT+1",zmc_m8,,6079,INF,"Backyard: 60 - Capturing at 39.08 fps, capturing bandwidth 399080bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:44:02 PM GMT+1",zmc_m8,,6106,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:44:02 PM GMT+1",zmc_m8,,6106,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:44:02 PM GMT+1",zmc_m8,,6106,WAR,"non increasing dts, fixing. our dts -7200 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:44:02 PM GMT+1",zmc_m8,,6106,WAR,"non increasing dts, fixing. our dts -10799 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:44:02 PM GMT+1",zmc_m8,,6106,WAR,"non increasing dts, fixing. our dts -14400 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:44:02 PM GMT+1",zmc_m8,,6106,WAR,"non increasing dts, fixing. our dts -18000 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:44:02 PM GMT+1",zmc_m8,,6106,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:44:02 PM GMT+1",zmc_m8,,6105,INF,"Backyard: 000 - Opened new event 2065, section start",zm_monitor.cpp,1938
"11/19/22, 8:44:02 PM GMT+1",zmc_m8,,6079,INF,"Backyard: 10 - Capturing at 6.14 fps, capturing bandwidth 177570bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:44:00 PM GMT+1",zmc_m8,,6079,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:42:55 PM GMT+1",zmc_m8,,5976,INF,"Backyard: 90 - Capturing at 25.00 fps, capturing bandwidth 482292bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:42:54 PM GMT+1",zmc_m8,,5976,INF,"Backyard: 60 - Capturing at 39.18 fps, capturing bandwidth 508485bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:42:53 PM GMT+1",zmc_m8,,5980,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:42:53 PM GMT+1",zmc_m8,,5980,WAR,"non increasing dts, fixing. our dts -3599 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:42:53 PM GMT+1",zmc_m8,,5980,WAR,"non increasing dts, fixing. our dts -7199 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:42:53 PM GMT+1",zmc_m8,,5980,WAR,"non increasing dts, fixing. our dts -10799 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:42:53 PM GMT+1",zmc_m8,,5980,WAR,"non increasing dts, fixing. our dts -14399 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:42:53 PM GMT+1",zmc_m8,,5980,WAR,"non increasing dts, fixing. our dts -17999 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:42:53 PM GMT+1",zmc_m8,,5980,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:42:53 PM GMT+1",zmc_m8,,5979,INF,"Backyard: 000 - Opened new event 2064, section start",zm_monitor.cpp,1938
"11/19/22, 8:42:53 PM GMT+1",zmc_m8,,5976,INF,"Backyard: 10 - Capturing at 6.15 fps, capturing bandwidth 180006bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:42:51 PM GMT+1",zmc_m8,,5976,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:41:45 PM GMT+1",zmc_m8,,5902,INF,"Backyard: 90 - Capturing at 25.00 fps, capturing bandwidth 448581bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:41:44 PM GMT+1",zmc_m8,,5902,INF,"Backyard: 60 - Capturing at 39.11 fps, capturing bandwidth 387364bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:41:42 PM GMT+1",zmc_m8,,5906,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:41:42 PM GMT+1",zmc_m8,,5906,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:41:42 PM GMT+1",zmc_m8,,5906,WAR,"non increasing dts, fixing. our dts -7200 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:41:42 PM GMT+1",zmc_m8,,5906,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:41:42 PM GMT+1",zmc_m8,,5906,WAR,"non increasing dts, fixing. our dts -14399 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:41:42 PM GMT+1",zmc_m8,,5906,WAR,"non increasing dts, fixing. our dts -18000 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:41:42 PM GMT+1",zmc_m8,,5906,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:41:42 PM GMT+1",zmc_m8,,5905,INF,"Backyard: 000 - Opened new event 2063, section start",zm_monitor.cpp,1938
"11/19/22, 8:41:42 PM GMT+1",zmc_m8,,5902,INF,"Backyard: 10 - Capturing at 6.21 fps, capturing bandwidth 169515bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:41:41 PM GMT+1",zmc_m8,,5902,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:40:35 PM GMT+1",zmc_m8,,5830,INF,"Backyard: 90 - Capturing at 24.99 fps, capturing bandwidth 395998bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:40:33 PM GMT+1",zmc_m8,,5830,INF,"Backyard: 60 - Capturing at 39.19 fps, capturing bandwidth 375787bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:40:32 PM GMT+1",zmc_m8,,5834,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:40:32 PM GMT+1",zmc_m8,,5834,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:40:32 PM GMT+1",zmc_m8,,5834,WAR,"non increasing dts, fixing. our dts -7200 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:40:32 PM GMT+1",zmc_m8,,5834,WAR,"non increasing dts, fixing. our dts -10799 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:40:32 PM GMT+1",zmc_m8,,5834,WAR,"non increasing dts, fixing. our dts -14400 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:40:32 PM GMT+1",zmc_m8,,5834,WAR,"non increasing dts, fixing. our dts -17999 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:40:32 PM GMT+1",zmc_m8,,5834,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:40:32 PM GMT+1",zmc_m8,,5833,INF,"Backyard: 000 - Opened new event 2062, section start",zm_monitor.cpp,1938
"11/19/22, 8:40:32 PM GMT+1",zmc_m8,,5830,INF,"Backyard: 10 - Capturing at 6.15 fps, capturing bandwidth 179662bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:40:31 PM GMT+1",zmc_m8,,5830,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:39:25 PM GMT+1",zmc_m8,,5752,INF,"Backyard: 90 - Capturing at 25.00 fps, capturing bandwidth 382953bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:39:23 PM GMT+1",zmc_m8,,5752,INF,"Backyard: 60 - Capturing at 39.56 fps, capturing bandwidth 403470bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:39:22 PM GMT+1",zmc_m8,,5756,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:39:22 PM GMT+1",zmc_m8,,5756,WAR,"non increasing dts, fixing. our dts -3599 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:39:22 PM GMT+1",zmc_m8,,5756,WAR,"non increasing dts, fixing. our dts -7200 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:39:22 PM GMT+1",zmc_m8,,5756,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:39:22 PM GMT+1",zmc_m8,,5756,WAR,"non increasing dts, fixing. our dts -14399 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:39:22 PM GMT+1",zmc_m8,,5756,WAR,"non increasing dts, fixing. our dts -18000 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:39:22 PM GMT+1",zmc_m8,,5756,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:39:22 PM GMT+1",zmc_m8,,5755,INF,"Backyard: 000 - Opened new event 2055, section start",zm_monitor.cpp,1938
"11/19/22, 8:39:22 PM GMT+1",zmc_m8,,5752,INF,"Backyard: 10 - Capturing at 5.91 fps, capturing bandwidth 186093bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:39:20 PM GMT+1",zmc_m8,,5752,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:39:04 PM GMT+1",zms_m8,,5601,ERR,"Monitor shm is not connected",zm_stream.cpp,78
"11/19/22, 8:39:04 PM GMT+1",zms_m8,,5635,ERR,"Monitor shm is not connected",zm_stream.cpp,78
"11/19/22, 8:38:17 PM GMT+1",zmc_m8,,5525,INF,"Backyard: 90 - Capturing at 25.01 fps, capturing bandwidth 382576bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:38:16 PM GMT+1",zmc_m8,,5525,INF,"Backyard: 60 - Capturing at 39.52 fps, capturing bandwidth 392321bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:38:15 PM GMT+1",zmc_m8,,5551,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:38:15 PM GMT+1",zmc_m8,,5551,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:38:15 PM GMT+1",zmc_m8,,5551,WAR,"non increasing dts, fixing. our dts -7200 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:38:15 PM GMT+1",zmc_m8,,5551,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:38:15 PM GMT+1",zmc_m8,,5551,WAR,"non increasing dts, fixing. our dts -14400 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:38:15 PM GMT+1",zmc_m8,,5551,WAR,"non increasing dts, fixing. our dts -18000 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:38:15 PM GMT+1",zmc_m8,,5551,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:38:15 PM GMT+1",zmc_m8,,5550,INF,"Backyard: 000 - Opened new event 2054, section start",zm_monitor.cpp,1938
"11/19/22, 8:38:15 PM GMT+1",zmc_m8,,5525,INF,"Backyard: 10 - Capturing at 6.01 fps, capturing bandwidth 167623bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:38:13 PM GMT+1",zmc_m8,,5525,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:38:13 PM GMT+1",zmc_m8,,5513,INF,"Backyard: image_count:62 - Closing event 2053, shutting down",zm_monitor.cpp,3062
"11/19/22, 8:38:13 PM GMT+1",zmc_m8,,5513,INF,"Backyard: 60 - Capturing at 39.17 fps, capturing bandwidth 514161bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:38:12 PM GMT+1",zmc_m8,,5517,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:38:12 PM GMT+1",zmc_m8,,5517,WAR,"non increasing dts, fixing. our dts -1 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:38:12 PM GMT+1",zmc_m8,,5517,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:38:12 PM GMT+1",zmc_m8,,5517,WAR,"non increasing dts, fixing. our dts -7201 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:38:12 PM GMT+1",zmc_m8,,5517,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:38:12 PM GMT+1",zmc_m8,,5517,WAR,"non increasing dts, fixing. our dts -14401 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:38:12 PM GMT+1",zmc_m8,,5517,WAR,"non increasing dts, fixing. our dts -18000 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:38:12 PM GMT+1",zmc_m8,,5517,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:38:12 PM GMT+1",zmc_m8,,5516,INF,"Backyard: 000 - Opened new event 2053, section start",zm_monitor.cpp,1938
"11/19/22, 8:38:12 PM GMT+1",zmc_m8,,5513,INF,"Backyard: 10 - Capturing at 6.18 fps, capturing bandwidth 180556bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:38:10 PM GMT+1",zmc_m8,,5513,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:37:04 PM GMT+1",zmc_m8,,5350,INF,"Backyard: 90 - Capturing at 24.98 fps, capturing bandwidth 455351bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:37:03 PM GMT+1",zmc_m8,,5350,INF,"Backyard: 60 - Capturing at 39.36 fps, capturing bandwidth 495099bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:37:02 PM GMT+1",zmc_m8,,5354,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:37:02 PM GMT+1",zmc_m8,,5354,WAR,"non increasing dts, fixing. our dts -3599 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:37:02 PM GMT+1",zmc_m8,,5354,WAR,"non increasing dts, fixing. our dts -7199 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:37:02 PM GMT+1",zmc_m8,,5354,WAR,"non increasing dts, fixing. our dts -10799 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:37:02 PM GMT+1",zmc_m8,,5354,WAR,"non increasing dts, fixing. our dts -14399 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:37:02 PM GMT+1",zmc_m8,,5354,WAR,"non increasing dts, fixing. our dts -17999 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:37:02 PM GMT+1",zmc_m8,,5354,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:37:02 PM GMT+1",zmc_m8,,5353,INF,"Backyard: 000 - Opened new event 2052, section start",zm_monitor.cpp,1938
"11/19/22, 8:37:02 PM GMT+1",zmc_m8,,5350,INF,"Backyard: 10 - Capturing at 6.25 fps, capturing bandwidth 190848bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:37:00 PM GMT+1",zmc_m8,,5350,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:35:54 PM GMT+1",zmc_m8,,4594,INF,"Backyard: 90 - Capturing at 24.78 fps, capturing bandwidth 426898bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:35:53 PM GMT+1",zmc_m8,,4594,INF,"Backyard: 60 - Capturing at 39.29 fps, capturing bandwidth 382846bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:35:52 PM GMT+1",zmc_m8,,4599,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:35:52 PM GMT+1",zmc_m8,,4599,WAR,"non increasing dts, fixing. our dts -1 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:35:52 PM GMT+1",zmc_m8,,4599,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:35:52 PM GMT+1",zmc_m8,,4599,WAR,"non increasing dts, fixing. our dts -7201 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:35:52 PM GMT+1",zmc_m8,,4599,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:35:52 PM GMT+1",zmc_m8,,4599,WAR,"non increasing dts, fixing. our dts -14400 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:35:52 PM GMT+1",zmc_m8,,4599,WAR,"non increasing dts, fixing. our dts -18001 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:35:52 PM GMT+1",zmc_m8,,4599,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:35:52 PM GMT+1",zmc_m8,,4598,INF,"Backyard: 000 - Opened new event 2051, section start",zm_monitor.cpp,1938
"11/19/22, 8:35:52 PM GMT+1",zmc_m8,,4594,INF,"Backyard: 10 - Capturing at 5.99 fps, capturing bandwidth 169237bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:35:50 PM GMT+1",zmc_m8,,4594,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:34:44 PM GMT+1",zmc_m8,,4409,INF,"Backyard: 90 - Capturing at 25.00 fps, capturing bandwidth 391673bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:34:43 PM GMT+1",zmc_m8,,4409,INF,"Backyard: 60 - Capturing at 39.19 fps, capturing bandwidth 453242bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:34:41 PM GMT+1",zmc_m8,,4417,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:34:41 PM GMT+1",zmc_m8,,4417,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:34:41 PM GMT+1",zmc_m8,,4417,WAR,"non increasing dts, fixing. our dts -7200 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:34:41 PM GMT+1",zmc_m8,,4417,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:34:41 PM GMT+1",zmc_m8,,4417,WAR,"non increasing dts, fixing. our dts -14400 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:34:41 PM GMT+1",zmc_m8,,4417,WAR,"non increasing dts, fixing. our dts -18000 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:34:41 PM GMT+1",zmc_m8,,4417,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:34:41 PM GMT+1",zmc_m8,,4416,INF,"Backyard: 000 - Opened new event 2049, section start",zm_monitor.cpp,1938
"11/19/22, 8:34:41 PM GMT+1",zmc_m8,,4409,INF,"Backyard: 10 - Capturing at 6.12 fps, capturing bandwidth 165617bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:34:40 PM GMT+1",zmc_m8,,4409,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:33:36 PM GMT+1",zmc_m8,,4329,INF,"Backyard: 90 - Capturing at 25.00 fps, capturing bandwidth 398199bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:33:35 PM GMT+1",zmc_m8,,4329,INF,"Backyard: 60 - Capturing at 39.20 fps, capturing bandwidth 425329bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:33:34 PM GMT+1",zmc_m8,,4333,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:33:34 PM GMT+1",zmc_m8,,4333,WAR,"non increasing dts, fixing. our dts -1 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:33:34 PM GMT+1",zmc_m8,,4333,WAR,"non increasing dts, fixing. our dts -3601 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:33:34 PM GMT+1",zmc_m8,,4333,WAR,"non increasing dts, fixing. our dts -7201 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:33:34 PM GMT+1",zmc_m8,,4333,WAR,"non increasing dts, fixing. our dts -10799 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:33:34 PM GMT+1",zmc_m8,,4333,WAR,"non increasing dts, fixing. our dts -14401 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:33:34 PM GMT+1",zmc_m8,,4333,WAR,"non increasing dts, fixing. our dts -18001 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:33:34 PM GMT+1",zmc_m8,,4333,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:33:34 PM GMT+1",zmc_m8,,4332,INF,"Backyard: 000 - Opened new event 2048, section start",zm_monitor.cpp,1938
"11/19/22, 8:33:34 PM GMT+1",zmc_m8,,4329,INF,"Backyard: 10 - Capturing at 6.10 fps, capturing bandwidth 167298bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:33:32 PM GMT+1",zmc_m8,,4329,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:33:31 PM GMT+1",zmc_m8,,4243,INF,"Backyard: image_count:1299 - Closing event 2047, shutting down",zm_monitor.cpp,3062
"11/19/22, 8:33:27 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 1200 - Capturing at 25.00 fps, capturing bandwidth 367233bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:33:23 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 1100 - Capturing at 25.05 fps, capturing bandwidth 377381bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:33:19 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 1000 - Capturing at 25.01 fps, capturing bandwidth 398118bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:33:15 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 900 - Capturing at 25.00 fps, capturing bandwidth 414977bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:33:11 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 800 - Capturing at 24.98 fps, capturing bandwidth 359678bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:33:07 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 700 - Capturing at 24.96 fps, capturing bandwidth 414167bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:33:03 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 600 - Capturing at 25.00 fps, capturing bandwidth 340684bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:32:59 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 500 - Capturing at 25.01 fps, capturing bandwidth 365062bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:32:55 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 400 - Capturing at 24.99 fps, capturing bandwidth 351844bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:32:51 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 300 - Capturing at 25.00 fps, capturing bandwidth 280173bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:32:47 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 200 - Capturing at 25.00 fps, capturing bandwidth 318563bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:32:43 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 90 - Capturing at 24.99 fps, capturing bandwidth 465963bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:32:41 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 60 - Capturing at 39.36 fps, capturing bandwidth 573928bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:32:40 PM GMT+1",zmc_m8,,4247,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:32:40 PM GMT+1",zmc_m8,,4247,WAR,"non increasing dts, fixing. our dts -3599 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:32:40 PM GMT+1",zmc_m8,,4247,WAR,"non increasing dts, fixing. our dts -7201 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:32:40 PM GMT+1",zmc_m8,,4247,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:32:40 PM GMT+1",zmc_m8,,4247,WAR,"non increasing dts, fixing. our dts -14401 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:32:40 PM GMT+1",zmc_m8,,4247,WAR,"non increasing dts, fixing. our dts -18000 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:32:40 PM GMT+1",zmc_m8,,4247,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:32:40 PM GMT+1",zmc_m8,,4246,INF,"Backyard: 000 - Opened new event 2047, section start",zm_monitor.cpp,1938
"11/19/22, 8:32:40 PM GMT+1",zmc_m8,,4243,INF,"Backyard: 10 - Capturing at 6.29 fps, capturing bandwidth 186128bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:32:40 PM GMT+1",zmc_m8,,4243,WAR,"Monitor dimensions are 1920x1080 but camera is sending 1080x1920",zm_ffmpeg_camera.cpp,579
"11/19/22, 8:32:38 PM GMT+1",zmc_m8,,4243,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:31:43 PM GMT+1",zmc_m8,,4119,INF,"Backyard: 90 - Capturing at 24.98 fps, capturing bandwidth 417635bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:31:42 PM GMT+1",zmc_m8,,4119,INF,"Backyard: 60 - Capturing at 39.25 fps, capturing bandwidth 447296bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:31:41 PM GMT+1",zmc_m8,,4123,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:31:41 PM GMT+1",zmc_m8,,4123,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:31:41 PM GMT+1",zmc_m8,,4123,WAR,"non increasing dts, fixing. our dts -7200 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:31:41 PM GMT+1",zmc_m8,,4123,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:31:41 PM GMT+1",zmc_m8,,4123,WAR,"non increasing dts, fixing. our dts -14400 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:31:41 PM GMT+1",zmc_m8,,4123,WAR,"non increasing dts, fixing. our dts -17999 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:31:41 PM GMT+1",zmc_m8,,4123,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:31:41 PM GMT+1",zmc_m8,,4122,INF,"Backyard: 000 - Opened new event 2046, section start",zm_monitor.cpp,1938
"11/19/22, 8:31:41 PM GMT+1",zmc_m8,,4119,INF,"Backyard: 10 - Capturing at 6.28 fps, capturing bandwidth 159933bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:31:39 PM GMT+1",zmc_m8,,4119,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:30:33 PM GMT+1",zmc_m8,,4032,INF,"Backyard: 90 - Capturing at 25.00 fps, capturing bandwidth 450150bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:30:32 PM GMT+1",zmc_m8,,4032,INF,"Backyard: 60 - Capturing at 39.48 fps, capturing bandwidth 432248bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:30:31 PM GMT+1",zmc_m8,,4036,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/19/22, 8:30:31 PM GMT+1",zmc_m8,,4036,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:30:31 PM GMT+1",zmc_m8,,4036,WAR,"non increasing dts, fixing. our dts -7199 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:30:31 PM GMT+1",zmc_m8,,4036,WAR,"non increasing dts, fixing. our dts -10799 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:30:31 PM GMT+1",zmc_m8,,4036,WAR,"non increasing dts, fixing. our dts -14399 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:30:31 PM GMT+1",zmc_m8,,4036,WAR,"non increasing dts, fixing. our dts -18000 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/19/22, 8:30:31 PM GMT+1",zmc_m8,,4036,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/19/22, 8:30:31 PM GMT+1",zmc_m8,,4035,INF,"Backyard: 000 - Opened new event 2045, section start",zm_monitor.cpp,1938
"11/19/22, 8:30:31 PM GMT+1",zmc_m8,,4032,INF,"Backyard: 10 - Capturing at 6.05 fps, capturing bandwidth 196041bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/19/22, 8:30:29 PM GMT+1",zmc_m8,,4032,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/19/22, 8:30:24 PM GMT+1",zms_m8,,3974,ERR,"Monitor shm is not connected",zm_stream.cpp,78
Camera settings are:
General - Source Type Ffmpg
General - Function Record
Source - Sourcepath rtsp://user:pass@cam-backyard.example.com/axis-media/media.amp
Source - Method TCP
Source - Capture Resolution 1080x1920
Storage - Save JPEGs Analysis images only (if available)
Storage - Video Writer Camera Passthrough
Timestamp - Timestamp Label Format <empty>
Also the event list shows that only a few frames/secs are recorded, no continuous recording, very frequent start of new events:
2038,"New Event
",Backyard,"Continuous
","11/19/22, 8:29:26 PM GMT+1",'-,00:00:02,100,0,0,0,0,bulkstore,4.95MB,
2036,"New Event
","11/19/22, 8:22:30 PM GMT+1",'-,00:00:02,100,0,0,0,0,bulkstore,1.69MB,
2035,"New Event
","11/19/22, 8:21:26 PM GMT+1",'-,00:00:00,null,null,0,0,0,bulkstore,36.00B,
2034,"Event-2034
","11/19/22, 8:20:40 PM GMT+1","11/19/22, 8:20:53 PM GMT+1",00:00:12,73,0,0,0,0,bulkstore,1.11MB,
2033,"New Event
","11/19/22, 8:19:30 PM GMT+1",'-,00:00:02,100,0,0,0,0,bulkstore,1.44MB,
2032,"New Event
","11/19/22, 8:18:20 PM GMT+1",'-,00:00:02,100,0,0,0,0,bulkstore,1.44MB,
2031,"New Event
","11/19/22, 8:17:08 PM GMT+1",'-,00:00:02,100,0,0,0,0,bulkstore,1.69MB,
2030,"New Event
","11/19/22, 8:16:15 PM GMT+1",'-,00:00:02,100,0,0,0,0,bulkstore,1.44MB,
2025,"New Event
","11/19/22, 8:15:10 PM GMT+1",'-,00:00:02,100,0,0,0,0,bulkstore,1.69MB,
2021,"New Event
","11/19/22, 8:13:59 PM GMT+1",'-,00:00:02,100,0,0,0,0,bulkstore,1.44MB,
The other cameras with similar settings are behaving ok. I can create continuous recordings with ffmpeg for this camera from the command line:
# ffmpeg -i rtsp://user:pass@cam-backyard.example.com/axis-media/media.amp test.mp4
ffmpeg version 4.4.2-0ubuntu0.22.04.1 Copyright (c) 2000-2021 the FFmpeg developers
  built with gcc 11 (Ubuntu 11.2.0-19ubuntu1)
  configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
  libavutil      56. 70.100 / 56. 70.100
  libavcodec     58.134.100 / 58.134.100
  libavformat    58. 76.100 / 58. 76.100
  libavdevice    58. 13.100 / 58. 13.100
  libavfilter     7.110.100 /  7.110.100
  libswscale      5.  9.100 /  5.  9.100
  libswresample   3.  9.100 /  3.  9.100
  libpostproc    55.  9.100 / 55.  9.100
Input #0, rtsp, from 'rtsp://user:pass@cam-backyard.example.com/axis-media/media.amp':
  Metadata:
    title           : Session streamed with GStreamer
    comment         : rtsp-server
  Duration: N/A, start: 0.239978, bitrate: N/A
  Stream #0:0: Video: h264 (High), yuvj420p(pc, bt709, progressive), 1080x1920 [SAR 1:1 DAR 9:16], 25 fps, 25 tbr, 90k tbn, 50 tbc
File 'test.mp4' already exists. Overwrite? [y/N] y
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264))
Press [q] to stop, [?] for help
[libx264 @ 0x55bef7a927c0] using SAR=1/1
[libx264 @ 0x55bef7a927c0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
[libx264 @ 0x55bef7a927c0] profile High, level 4.0, 4:2:0, 8-bit
[libx264 @ 0x55bef7a927c0] 264 - core 163 r3060 5db6aa6 - H.264/MPEG-4 AVC codec - Copyleft 2003-2021 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
Output #0, mp4, to 'test.mp4':
  Metadata:
    encoder         : Lavf58.76.100
  Stream #0:0: Video: h264 (avc1 / 0x31637661), yuvj420p(pc, bt709, progressive), 1080x1920 [SAR 1:1 DAR 9:16], q=2-31, 25 fps, 12800 tbn
    Metadata:
      encoder         : Lavc58.134.100 libx264
    Side data:
      cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: N/A
frame=    1 fps=0.0 q=0.0 size=       0kB time=00:00:00.00 bitrate=N/A speed=   [rtsp @ 0x55bef78d7680] max delay reached. need to consume packet
[rtsp @ 0x55bef78d7680] RTP: missed 268 packets
frame=   51 fps=0.0 q=0.0 size=       0kB time=00:00:00.00 bitrate=N/A dup=0 dro
frame=   51 fps= 48 q=0.0 size=       0kB time=00:00:00.00 bitrate=N/A dup=0 dro
frame=   51 fps= 32 q=0.0 size=       0kB time=00:00:00.00 bitrate=N/A dup=0 dro
frame=   51 fps= 24 q=0.0 size=       0kB time=00:00:00.00 bitrate=N/A dup=0 dro
frame=  112 fps= 41 q=28.0 size=     768kB time=00:00:02.12 bitrate=2967.7kbits/
frame=  139 fps= 43 q=28.0 size=     768kB time=00:00:03.20 bitrate=1966.2kbits/
frame=  152 fps= 40 q=28.0 size=     768kB time=00:00:03.72 bitrate=1691.3kbits/
frame=  165 fps= 38 q=28.0 size=     768kB time=00:00:04.24 bitrate=1483.9kbits/
frame=  178 fps= 37 q=28.0 size=    1024kB time=00:00:04.76 bitrate=1762.4kbits/
frame=  191 fps= 36 q=28.0 size=    1280kB time=00:00:05.28 bitrate=1986.0kbits/
frame=  204 fps= 35 q=28.0 size=    1280kB time=00:00:05.80 bitrate=1807.9kbits/
frame=  217 fps= 34 q=28.0 size=    1536kB time=00:00:06.32 bitrate=1991.0kbits/
frame=  230 fps= 33 q=28.0 size=    1536kB time=00:00:06.84 bitrate=1839.6kbits/
frame=  243 fps= 33 q=28.0 size=    1792kB time=00:00:07.36 bitrate=1994.6kbits/
frame=  256 fps= 32 q=28.0 size=    2048kB time=00:00:07.88 bitrate=2129.1kbits/
frame=  269 fps= 32 q=28.0 size=    2304kB time=00:00:08.40 bitrate=2247.0kbits/
frame=  282 fps= 31 q=28.0 size=    2304kB time=00:00:08.92 bitrate=2116.0kbits/
frame=  295 fps= 31 q=28.0 size=    2304kB time=00:00:09.44 bitrate=1999.4kbits/
frame=  308 fps= 31 q=28.0 size=    2816kB time=00:00:09.96 bitrate=2316.2kbits/
frame=  321 fps= 30 q=28.0 size=    3072kB time=00:00:10.48 bitrate=2401.3kbits/
frame=  334 fps= 30 q=28.0 size=    3328kB time=00:00:11.00 bitrate=2478.5kbits/
frame=  347 fps= 30 q=28.0 size=    3328kB time=00:00:11.52 bitrate=2366.6kbits/
frame=  360 fps= 30 q=28.0 size=    3584kB time=00:00:12.04 bitrate=2438.6kbits/
frame=  373 fps= 30 q=28.0 size=    3840kB time=00:00:12.56 bitrate=2504.6kbits/
frame=  386 fps= 29 q=28.0 size=    3840kB time=00:00:13.08 bitrate=2405.0kbits/
frame=  399 fps= 29 q=28.0 size=    4096kB time=00:00:13.60 bitrate=2467.3kbits/
frame=  412 fps= 29 q=28.0 size=    4096kB time=00:00:14.12 bitrate=2376.4kbits/
frame=  425 fps= 29 q=28.0 size=    4352kB time=00:00:14.64 bitrate=2435.2kbits/
frame=  438 fps= 29 q=28.0 size=    4352kB time=00:00:15.16 bitrate=2351.7kbits/
frame=  451 fps= 29 q=28.0 size=    4608kB time=00:00:15.68 bitrate=2407.5kbits/
frame=  464 fps= 29 q=28.0 size=    4608kB time=00:00:16.20 bitrate=2330.2kbits/
frame=  477 fps= 28 q=28.0 size=    4864kB time=00:00:16.72 bitrate=2383.1kbits/
frame=  490 fps= 28 q=28.0 size=    5120kB time=00:00:17.24 bitrate=2432.9kbits/
frame=  503 fps= 28 q=28.0 size=    5376kB time=00:00:17.76 bitrate=2479.8kbits/
frame=  516 fps= 28 q=28.0 size=    5376kB time=00:00:18.28 bitrate=2409.2kbits/
frame=  529 fps= 28 q=28.0 size=    5632kB time=00:00:18.80 bitrate=2454.1kbits/
frame=  542 fps= 28 q=28.0 size=    5632kB time=00:00:19.32 bitrate=2388.1kbits/
frame=  555 fps= 28 q=28.0 size=    5888kB time=00:00:19.84 bitrate=2431.2kbits/
frame=  568 fps= 28 q=28.0 size=    6144kB time=00:00:20.36 bitrate=2472.1kbits/
frame=  581 fps= 28 q=28.0 size=    6400kB time=00:00:20.88 bitrate=2511.0kbits/
frame=  594 fps= 28 q=28.0 size=    6400kB time=00:00:21.40 bitrate=2450.0kbits/
frame=  606 fps= 27 q=-1.0 Lsize=    7338kB time=00:00:24.12 bitrate=2492.1kbits/s dup=59 drop=4 speed=1.08x
video:7333kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.067416%
[libx264 @ 0x55bef7a927c0] frame I:3     Avg QP:19.09  size:225284
[libx264 @ 0x55bef7a927c0] frame P:474   Avg QP:21.24  size: 13602
[libx264 @ 0x55bef7a927c0] frame B:129   Avg QP:28.80  size:  2982
[libx264 @ 0x55bef7a927c0] consecutive B-frames: 71.1%  1.3%  0.5% 27.1%
[libx264 @ 0x55bef7a927c0] mb I  I16..4:  1.9% 53.8% 44.3%
[libx264 @ 0x55bef7a927c0] mb P  I16..4:  0.0%  0.5%  0.2%  P16..4: 14.2%  5.8%  3.6%  0.0%  0.0%    skip:75.6%
[libx264 @ 0x55bef7a927c0] mb B  I16..4:  0.0%  0.0%  0.0%  B16..8: 23.8%  1.5%  0.2%  direct: 0.4%  skip:74.1%  L0:45.9% L1:52.9% BI: 1.3%
[libx264 @ 0x55bef7a927c0] 8x8 transform intra:64.3% inter:80.3%
[libx264 @ 0x55bef7a927c0] coded y,uvDC,uvAC intra: 96.1% 0.0% 0.0% inter: 6.6% 0.0% 0.0%
[libx264 @ 0x55bef7a927c0] i16 v,h,dc,p:  9%  7% 21% 63%
[libx264 @ 0x55bef7a927c0] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 16% 17%  6%  7%  8%  7%  8% 11%
[libx264 @ 0x55bef7a927c0] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 23% 11%  6%  7%  7%  6%  8%  8%
[libx264 @ 0x55bef7a927c0] i8c dc,h,v,p: 100%  0%  0%  0%
[libx264 @ 0x55bef7a927c0] Weighted P-Frames: Y:0.0% UV:0.0%
[libx264 @ 0x55bef7a927c0] ref P L0: 84.4%  8.6%  5.6%  1.3%
[libx264 @ 0x55bef7a927c0] ref B L0: 93.4%  6.0%  0.6%
[libx264 @ 0x55bef7a927c0] ref B L1: 94.7%  5.3%
[libx264 @ 0x55bef7a927c0] kb/s:2477.87
Exiting normally, received signal 2.
What am I doing wrong, please? Happy to provide additional information, if needed.
NotSoWittyName
Re: 9:16 camera image = problem?
For what it's worth: If I set back the camera image to 0 deg rotation, i.e. 1920x1080, ZM runs fine. Then turning the image again for 90 deg, the errors occur again. The below log starts (at the bottom, of course) with the reported errors, then shows that things are running fine at 1920x1080, and then shows the errors again with the image rotated again to 1080x1920:
"11/20/22, 8:57:14 AM GMT+1",zmc_m8,,13726,INF,"Backyard: 90 - Capturing at 25.01 fps, capturing bandwidth 849009bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:57:13 AM GMT+1",zmc_m8,,13726,INF,"Backyard: 60 - Capturing at 39.06 fps, capturing bandwidth 651684bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:57:12 AM GMT+1",zmc_m8,,13731,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/20/22, 8:57:12 AM GMT+1",zmc_m8,,13731,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:57:12 AM GMT+1",zmc_m8,,13731,WAR,"non increasing dts, fixing. our dts -7202 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:57:12 AM GMT+1",zmc_m8,,13731,WAR,"non increasing dts, fixing. our dts -10801 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:57:12 AM GMT+1",zmc_m8,,13731,WAR,"non increasing dts, fixing. our dts -14400 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:57:12 AM GMT+1",zmc_m8,,13731,WAR,"non increasing dts, fixing. our dts -18000 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:57:12 AM GMT+1",zmc_m8,,13731,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/20/22, 8:57:12 AM GMT+1",zmc_m8,,13730,INF,"Backyard: 000 - Opened new event 3211, section start",zm_monitor.cpp,1938
"11/20/22, 8:57:12 AM GMT+1",zmc_m8,,13726,INF,"Backyard: 10 - Capturing at 6.33 fps, capturing bandwidth 476704bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:57:10 AM GMT+1",zmc_m8,,13726,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/20/22, 8:56:04 AM GMT+1",zmc_m8,,13620,INF,"Backyard: 90 - Capturing at 25.03 fps, capturing bandwidth 971619bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:56:03 AM GMT+1",zmc_m8,,13620,INF,"Backyard: 60 - Capturing at 39.15 fps, capturing bandwidth 828327bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:56:01 AM GMT+1",zmc_m8,,13624,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/20/22, 8:56:01 AM GMT+1",zmc_m8,,13624,WAR,"non increasing dts, fixing. our dts -3599 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:56:01 AM GMT+1",zmc_m8,,13624,WAR,"non increasing dts, fixing. our dts -7199 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:56:01 AM GMT+1",zmc_m8,,13624,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:56:01 AM GMT+1",zmc_m8,,13624,WAR,"non increasing dts, fixing. our dts -14399 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:56:01 AM GMT+1",zmc_m8,,13624,WAR,"non increasing dts, fixing. our dts -17999 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:56:01 AM GMT+1",zmc_m8,,13624,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/20/22, 8:56:01 AM GMT+1",zmc_m8,,13623,INF,"Backyard: 000 - Opened new event 3210, section start",zm_monitor.cpp,1938
"11/20/22, 8:56:01 AM GMT+1",zmc_m8,,13620,INF,"Backyard: 10 - Capturing at 6.03 fps, capturing bandwidth 474692bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:56:00 AM GMT+1",zmc_m8,,13620,INF,"Starting Capture version 1.36.31",zmc.cpp,220
[change back to 1080x1920]
"11/20/22, 8:55:58 AM GMT+1",zmc_m8,,13464,INF,"Backyard: image_count:3049 - Closing event 3208, shutting down",zm_monitor.cpp,3062
"11/20/22, 8:55:56 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 3000 - Capturing at 25.00 fps, capturing bandwidth 798506bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:52 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 2900 - Capturing at 25.00 fps, capturing bandwidth 622302bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:48 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 2800 - Capturing at 25.02 fps, capturing bandwidth 717646bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:44 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 2700 - Capturing at 24.98 fps, capturing bandwidth 675699bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:40 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 2600 - Capturing at 25.03 fps, capturing bandwidth 583303bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:36 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 2500 - Capturing at 25.00 fps, capturing bandwidth 758833bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:32 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 2400 - Capturing at 24.98 fps, capturing bandwidth 629787bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:28 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 2300 - Capturing at 25.01 fps, capturing bandwidth 766261bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:24 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 2200 - Capturing at 25.06 fps, capturing bandwidth 754465bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:20 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 2100 - Capturing at 24.97 fps, capturing bandwidth 637241bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:16 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 2000 - Capturing at 24.96 fps, capturing bandwidth 720348bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:12 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 1900 - Capturing at 25.02 fps, capturing bandwidth 593422bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:08 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 1800 - Capturing at 24.98 fps, capturing bandwidth 731061bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:04 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 1700 - Capturing at 24.99 fps, capturing bandwidth 803776bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:55:00 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 1600 - Capturing at 24.99 fps, capturing bandwidth 654531bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:56 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 1500 - Capturing at 25.00 fps, capturing bandwidth 794847bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:52 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 1400 - Capturing at 24.99 fps, capturing bandwidth 778306bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:48 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 1300 - Capturing at 25.01 fps, capturing bandwidth 658935bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:44 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 1200 - Capturing at 25.00 fps, capturing bandwidth 828811bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:40 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 1100 - Capturing at 25.00 fps, capturing bandwidth 667236bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:36 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 1000 - Capturing at 25.01 fps, capturing bandwidth 809284bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:32 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 900 - Capturing at 24.98 fps, capturing bandwidth 825772bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:28 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 800 - Capturing at 25.00 fps, capturing bandwidth 699519bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:24 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 700 - Capturing at 25.00 fps, capturing bandwidth 884193bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:20 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 600 - Capturing at 26.30 fps, capturing bandwidth 713206bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:17 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 500 - Capturing at 23.82 fps, capturing bandwidth 789341bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:12 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 400 - Capturing at 25.00 fps, capturing bandwidth 771206bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:08 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 300 - Capturing at 24.75 fps, capturing bandwidth 643372bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:04 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 200 - Capturing at 25.00 fps, capturing bandwidth 732668bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:54:00 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 90 - Capturing at 25.00 fps, capturing bandwidth 1020698bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:53:59 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 60 - Capturing at 39.30 fps, capturing bandwidth 1004214bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:53:58 AM GMT+1",zmc_m8,,13490,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/20/22, 8:53:58 AM GMT+1",zmc_m8,,13490,WAR,"non increasing dts, fixing. our dts -1 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:53:58 AM GMT+1",zmc_m8,,13490,WAR,"non increasing dts, fixing. our dts -3601 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:53:58 AM GMT+1",zmc_m8,,13490,WAR,"non increasing dts, fixing. our dts -7201 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:53:58 AM GMT+1",zmc_m8,,13490,WAR,"non increasing dts, fixing. our dts -10800 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:53:58 AM GMT+1",zmc_m8,,13490,WAR,"non increasing dts, fixing. our dts -14402 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:53:58 AM GMT+1",zmc_m8,,13490,WAR,"non increasing dts, fixing. our dts -18001 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:53:58 AM GMT+1",zmc_m8,,13490,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/20/22, 8:53:58 AM GMT+1",zmc_m8,,13489,INF,"Backyard: 000 - Opened new event 3208, section start",zm_monitor.cpp,1938
"11/20/22, 8:53:58 AM GMT+1",zmc_m8,,13464,INF,"Backyard: 10 - Capturing at 6.25 fps, capturing bandwidth 603232bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:53:56 AM GMT+1",zmc_m8,,13464,INF,"Starting Capture version 1.36.31",zmc.cpp,220
[change to 1920x1080]
"11/20/22, 8:52:46 AM GMT+1",zms_m8,,13410,ERR,"Monitor shm is not connected",zm_stream.cpp,78
"11/20/22, 8:51:44 AM GMT+1",zmc_m8,,13329,INF,"Backyard: 90 - Capturing at 24.99 fps, capturing bandwidth 1013432bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:51:43 AM GMT+1",zmc_m8,,13329,INF,"Backyard: 60 - Capturing at 39.32 fps, capturing bandwidth 756469bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:51:41 AM GMT+1",zmc_m8,,13333,WAR,"pkt.dts(0) must be",zm_videostore.cpp,1409
"11/20/22, 8:51:41 AM GMT+1",zmc_m8,,13333,WAR,"non increasing dts, fixing. our dts -3600 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:51:41 AM GMT+1",zmc_m8,,13333,WAR,"non increasing dts, fixing. our dts -7200 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:51:41 AM GMT+1",zmc_m8,,13333,WAR,"non increasing dts, fixing. our dts -10799 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:51:41 AM GMT+1",zmc_m8,,13333,WAR,"non increasing dts, fixing. our dts -14399 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:51:41 AM GMT+1",zmc_m8,,13333,WAR,"non increasing dts, fixing. our dts -17998 stream 0 last_dts 0. reorder_queue_size=0",zm_videostore.cpp,1398
"11/20/22, 8:51:41 AM GMT+1",zmc_m8,,13333,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/20/22, 8:51:41 AM GMT+1",zmc_m8,,13332,INF,"Backyard: 000 - Opened new event 3207, section start",zm_monitor.cpp,1938
"11/20/22, 8:51:41 AM GMT+1",zmc_m8,,13329,INF,"Backyard: 10 - Capturing at 6.20 fps, capturing bandwidth 483150bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 8:51:40 AM GMT+1",zmc_m8,,13329,INF,"Starting Capture version 1.36.31",zmc.cpp,220
Seeing those errors, you might want to try upping the reorder_queue.
NotSoWittyName
Setting "reorder_queue_size" in Storage - Optional Encoder Parameters removes the reorder-related errors (which occur with every camera here, so I probably should set this across the board). But the fundamental error with recordings stopping after a few secs are unchanged. At the bottom of the following log, you can see the ok ongoing recordings at 1920x1080. Once I change this to 1080x1920 in ZM and the campera, recording stops after a few secs, and then capture starts again automatically for a few frames...:
"11/20/22, 11:29:50 AM GMT+1",zmc_m8,,18559,INF,"Backyard: 70 - Capturing at 12.20 fps, capturing bandwidth 579379bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:29:48 AM GMT+1",zmc_m8,,18559,INF,"Backyard: 50 - Capturing at 21.77 fps, capturing bandwidth 410124bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:29:47 AM GMT+1",zmc_m8,,18563,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/20/22, 11:29:47 AM GMT+1",zmc_m8,,18562,INF,"Backyard: 000 - Opened new event 3344, section start",zm_monitor.cpp,1938
"11/20/22, 11:29:47 AM GMT+1",zmc_m8,,18559,INF,"Backyard: 10 - Capturing at 3.39 fps, capturing bandwidth 273700bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:29:44 AM GMT+1",zmc_m8,,18559,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/20/22, 11:28:42 AM GMT+1",zmc_m8,,18534,INF,"Backyard: 90 - Capturing at 11.94 fps, capturing bandwidth 189921bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:28:40 AM GMT+1",zmc_m8,,18534,INF,"Backyard: 70 - Capturing at 12.17 fps, capturing bandwidth 542260bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:28:38 AM GMT+1",zmc_m8,,18534,INF,"Backyard: 50 - Capturing at 21.77 fps, capturing bandwidth 457272bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:28:36 AM GMT+1",zmc_m8,,18538,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/20/22, 11:28:36 AM GMT+1",zmc_m8,,18537,INF,"Backyard: 000 - Opened new event 3343, section start",zm_monitor.cpp,1938
"11/20/22, 11:28:36 AM GMT+1",zmc_m8,,18534,INF,"Backyard: 10 - Capturing at 3.47 fps, capturing bandwidth 273433bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:28:34 AM GMT+1",zmc_m8,,18534,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/20/22, 11:28:24 AM GMT+1",zms_m8,,18516,ERR,"Monitor shm is not connected",zm_stream.cpp,78
"11/20/22, 11:27:31 AM GMT+1",zmc_m8,,18446,INF,"Backyard: 90 - Capturing at 11.85 fps, capturing bandwidth 704364bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:27:30 AM GMT+1",zmc_m8,,18446,INF,"Backyard: 70 - Capturing at 12.19 fps, capturing bandwidth 648507bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:27:28 AM GMT+1",zmc_m8,,18446,INF,"Backyard: 50 - Capturing at 21.81 fps, capturing bandwidth 528547bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:27:26 AM GMT+1",zmc_m8,,18450,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/20/22, 11:27:26 AM GMT+1",zmc_m8,,18449,INF,"Backyard: 000 - Opened new event 3342, section start",zm_monitor.cpp,1938
"11/20/22, 11:27:26 AM GMT+1",zmc_m8,,18446,INF,"Backyard: 10 - Capturing at 3.39 fps, capturing bandwidth 277485bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:27:23 AM GMT+1",zmc_m8,,18446,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/20/22, 11:27:08 AM GMT+1",zms_m8,,18405,ERR,"Monitor shm is not connected",zm_stream.cpp,78
"11/20/22, 11:27:07 AM GMT+1",zms_m8,,18386,ERR,"Monitor shm is not connected",zm_stream.cpp,78
"11/20/22, 11:27:07 AM GMT+1",zms_m8,,18405,ERR,"Monitor shm is not connected",zm_stream.cpp,78
"11/20/22, 11:27:07 AM GMT+1",zms_m8,,18396,ERR,"Monitor shm is not connected",zm_stream.cpp,78
"11/20/22, 11:26:19 AM GMT+1",zmc_m8,,18333,INF,"Backyard: 90 - Capturing at 11.88 fps, capturing bandwidth 249102bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:26:17 AM GMT+1",zmc_m8,,18333,INF,"Backyard: 70 - Capturing at 12.19 fps, capturing bandwidth 610521bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:26:16 AM GMT+1",zmc_m8,,18333,INF,"Backyard: 50 - Capturing at 21.78 fps, capturing bandwidth 393104bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:26:14 AM GMT+1",zmc_m8,,18360,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/20/22, 11:26:14 AM GMT+1",zmc_m8,,18359,INF,"Backyard: 000 - Opened new event 3341, section start",zm_monitor.cpp,1938
"11/20/22, 11:26:14 AM GMT+1",zmc_m8,,18333,INF,"Backyard: 10 - Capturing at 3.52 fps, capturing bandwidth 279259bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:26:11 AM GMT+1",zmc_m8,,18333,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/20/22, 11:26:11 AM GMT+1",zmc_m8,,18210,INF,"Backyard: image_count:1070 - Closing event 3339, shutting down",zm_monitor.cpp,3062
"11/20/22, 11:26:05 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 1000 - Capturing at 12.03 fps, capturing bandwidth 351135bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:25:57 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 900 - Capturing at 11.95 fps, capturing bandwidth 435575bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:25:48 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 800 - Capturing at 12.03 fps, capturing bandwidth 350617bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:25:40 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 700 - Capturing at 12.01 fps, capturing bandwidth 437525bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:25:32 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 600 - Capturing at 11.96 fps, capturing bandwidth 410064bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:25:23 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 500 - Capturing at 12.03 fps, capturing bandwidth 543656bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:25:15 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 400 - Capturing at 12.01 fps, capturing bandwidth 345816bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:25:07 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 300 - Capturing at 11.97 fps, capturing bandwidth 240911bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:24:58 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 200 - Capturing at 12.02 fps, capturing bandwidth 291300bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:24:49 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 90 - Capturing at 11.83 fps, capturing bandwidth 187352bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:24:47 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 70 - Capturing at 12.19 fps, capturing bandwidth 559471bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:24:46 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 50 - Capturing at 21.78 fps, capturing bandwidth 460598bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:24:44 AM GMT+1",zmc_m8,,18214,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/20/22, 11:24:44 AM GMT+1",zmc_m8,,18213,INF,"Backyard: 000 - Opened new event 3339, section start",zm_monitor.cpp,1938
"11/20/22, 11:24:44 AM GMT+1",zmc_m8,,18210,INF,"Backyard: 10 - Capturing at 3.38 fps, capturing bandwidth 256286bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:24:41 AM GMT+1",zmc_m8,,18210,INF,"Starting Capture version 1.36.31",zmc.cpp,220
"11/20/22, 11:24:40 AM GMT+1",zmc_m8,,15958,INF,"Backyard: image_count:84599 - Closing event 3334, shutting down",zm_monitor.cpp,3062
"11/20/22, 11:24:32 AM GMT+1",zmc_m8,,15958,INF,"Backyard: 84500 - Capturing at 12.01 fps, capturing bandwidth 320971bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:24:23 AM GMT+1",zmc_m8,,15958,INF,"Backyard: 84400 - Capturing at 12.03 fps, capturing bandwidth 387859bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:24:15 AM GMT+1",zmc_m8,,15958,INF,"Backyard: 84300 - Capturing at 11.96 fps, capturing bandwidth 344611bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:24:07 AM GMT+1",zmc_m8,,15958,INF,"Backyard: 84200 - Capturing at 12.02 fps, capturing bandwidth 448659bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:23:58 AM GMT+1",zmc_m8,,15958,INF,"Backyard: 84100 - Capturing at 12.02 fps, capturing bandwidth 348156bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
NotSoWittyName
Post by NotSoWittyName »
One more: If I change Capture Resolution in ZM to 1920 x 1080 even though the camera is still sending 1080 x 1920, recording does continue without an error:
"11/20/22, 11:36:13 AM GMT+1",zmc_m8,,19076,INF,"Backyard: 600 - Capturing at 11.97 fps, capturing bandwidth 353404bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:36:05 AM GMT+1",zmc_m8,,19076,INF,"Backyard: 500 - Capturing at 12.01 fps, capturing bandwidth 476138bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:35:56 AM GMT+1",zmc_m8,,19076,INF,"Backyard: 400 - Capturing at 12.02 fps, capturing bandwidth 451965bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:35:48 AM GMT+1",zmc_m8,,19076,INF,"Backyard: 300 - Capturing at 11.97 fps, capturing bandwidth 312695bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:35:40 AM GMT+1",zmc_m8,,19076,INF,"Backyard: 200 - Capturing at 12.00 fps, capturing bandwidth 373170bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:35:31 AM GMT+1",zmc_m8,,19076,INF,"Backyard: 90 - Capturing at 11.91 fps, capturing bandwidth 226790bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:35:29 AM GMT+1",zmc_m8,,19076,INF,"Backyard: 70 - Capturing at 12.18 fps, capturing bandwidth 576697bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:35:27 AM GMT+1",zmc_m8,,19076,INF,"Backyard: 50 - Capturing at 21.86 fps, capturing bandwidth 380237bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:35:25 AM GMT+1",zmc_m8,,19111,INF,"some options not used, turn on debugging for a list.",zm_videostore.cpp,532
"11/20/22, 11:35:25 AM GMT+1",zmc_m8,,19110,INF,"Backyard: 000 - Opened new event 3359, section start",zm_monitor.cpp,1938
"11/20/22, 11:35:25 AM GMT+1",zmc_m8,,19076,INF,"Backyard: 10 - Capturing at 3.49 fps, capturing bandwidth 274689bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1680
"11/20/22, 11:35:25 AM GMT+1",zmc_m8,,19076,WAR,"Monitor dimensions are 1920x1080 but camera is sending 1080x1920",zm_ffmpeg_camera.cpp,579
"11/20/22, 11:35:22 AM GMT+1",zmc_m8,,19076,INF,"Starting Capture version 1.36.31",zmc.cpp,220
So the interrupted recording appears to be related to the resolution setting in ZM...?
Get the usual debug level 3 and it might hold clues.
NotSoWittyName
Is this enough, or should I pastebin more?
11/20/22 15:39:29.963184 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:50 with keyframe:0, video frames in queue:75 max: 2, queuesize:75]
11/20/22 15:39:29.963487 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:51 with keyframe:0, video frames in queue:74 max: 2, queuesize:74]
11/20/22 15:39:29.964084 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:52 with keyframe:0, video frames in queue:73 max: 2, queuesize:73]
11/20/22 15:39:29.964439 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:53 with keyframe:0, video frames in queue:72 max: 2, queuesize:72]
11/20/22 15:39:29.964832 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:54 with keyframe:0, video frames in queue:71 max: 2, queuesize:71]
11/20/22 15:39:29.965268 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:55 with keyframe:0, video frames in queue:70 max: 2, queuesize:70]
11/20/22 15:39:29.965547 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:56 with keyframe:0, video frames in queue:69 max: 2, queuesize:69]
11/20/22 15:39:29.965995 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:57 with keyframe:0, video frames in queue:68 max: 2, queuesize:68]
11/20/22 15:39:29.966280 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:58 with keyframe:0, video frames in queue:67 max: 2, queuesize:67]
11/20/22 15:39:29.966688 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:59 with keyframe:0, video frames in queue:66 max: 2, queuesize:66]
11/20/22 15:39:29.966974 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:60 with keyframe:0, video frames in queue:65 max: 2, queuesize:65]
11/20/22 15:39:29.967401 zmc_m8[23474].DB1-zm_packetqueue.cpp/350 [Deleting a packet with stream index:0 image_index:61 with keyframe:0, video frames in queue:64 max: 2, queuesize:64]
11/20/22 15:39:29.967668 zmc_m8[23474].DB2-zm_packetqueue.cpp/530 [Incrementing 0x561b1d70b8c0, queue size 63, end? 0]
11/20/22 15:39:29.967672 zmc_m8[23474].DB2-zm_packetqueue.cpp/540 [At end]
11/20/22 15:39:29.967676 zmc_m8[23474].DB2-zm_packetqueue.cpp/445 [waiting.  Queue size 63 it == end? 1]
11/20/22 15:39:29.967689 zmc_m8[23475].DB1-zm_event.cpp/738 [Adding packet 124]
11/20/22 15:39:29.967699 zmc_m8[23475].DB2-zm_event.cpp/348 [have_video_keyframe 1 codec_type 0 == video? 1 packet keyframe 1]
11/20/22 15:39:29.967702 zmc_m8[23475].DB2-zm_event.cpp/350 [Adding to event: pts: 928797, dts: 928797, size: 582529, stream_index: 0, flags: 0001, keyframe(1) pos: -1, duration: 7500]
11/20/22 15:39:29.967707 zmc_m8[23475].DB1-zm_videostore.cpp/1054 [Queue size for 0 is 50]
11/20/22 15:39:29.967710 zmc_m8[23475].DB1-zm_videostore.cpp/1064 [Found in order packet]
11/20/22 15:39:29.967712 zmc_m8[23475].DB1-zm_videostore.cpp/1082 [Pushing on queue 0, size is 51]
11/20/22 15:39:29.967717 zmc_m8[23475].DB2-zm_videostore.cpp/1276 [Doing passthrough, just copy packet: pts: 554399 * 1/90000=6.159989, dts: 554399, size: 25358, stream_index: 0, video flags: 0000, keyframe(0) pos: -1, duration: 7500]
11/20/22 15:39:29.967727 zmc_m8[23475].DB2-zm_videostore.cpp/1419 [finished pkt: pts: 547199 * 1/90000=6.079989, dts: 547199, size: 25358, stream_index: 0, video flags: 0000, keyframe(0) pos: -1, duration: 7500]
11/20/22 15:39:29.967731 zmc_m8[23475].DB3-zm_videostore.cpp/1420 [next_dts for stream 0 has become 554699 last_dts 547199]
11/20/22 15:39:29.967752 zmc_m8[23475].DB1-zm_event.cpp/438 [Have frame type Normal from score(0) state 5 frames 125 bulk frame interval 100 and mod25]
11/20/22 15:39:29.967755 zmc_m8[23475].DB1-zm_event.cpp/460 [Not Writing snapshot because frames 125 score 0 > max 0]
11/20/22 15:39:29.969163 zmc_m8[23471].DB2-zm_ffmpeg_camera.cpp/238 [ffmpeg_camera in: pts: 935998 * 1/90000=10.399978, dts: 935998, size: 15482, stream_index: 0, video flags: 0000, keyframe(0) pos: -1, duration: 7500]
11/20/22 15:39:29.969189 zmc_m8[23471].DB2-zm_monitor.cpp/2418 [Have packet stream_index:0 ?= videostream_id: 0 q.vpktcount 63 event? 1 image_count 125]
11/20/22 15:39:29.969194 zmc_m8[23471].DB2-zm_packetqueue.cpp/112 [packet counts for 0 is 64]
11/20/22 15:39:29.969217 zmc_m8[23473].DB3-zm_packetqueue.cpp/501 [get_packet using it 0x561b1db19e60 locking index 125]
11/20/22 15:39:29.969223 zmc_m8[23473].DB2-zm_packetqueue.cpp/506 [Locked packet 125, unlocking packetqueue mutex, incrementing it]
11/20/22 15:39:29.969234 zmc_m8[23474].DB3-zm_packetqueue.cpp/455 [get_packet using it 0x561b1d70b8c0 locking index 125]
11/20/22 15:39:29.969241 zmc_m8[23474].DB2-zm_packetqueue.cpp/465 [waiting.  Queue size 64 it == end? 0]
11/20/22 15:39:29.969268 zmc_m8[23473].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2]
11/20/22 15:39:29.972913 zmc_m8[23473].DB1-zm_packet.cpp/130 [got frame: format 12 yuvj420p 1080x1920 linesize:1152x576 pts: 935998 keyframe: 0]
11/20/22 15:39:29.972937 zmc_m8[23473].DB3-zm_packet.cpp/208 [Same pix format yuvj420p so not hwtransferring. sw_pix_fmt is yuvj420p]
11/20/22 15:39:29.973001 zmc_m8[23473].DB1-zm_image.cpp/253 [PopulateFrame: width 1080 height 1920 linesize 4320 colours 4 imagesize 8294400 rgba]
11/20/22 15:39:29.973005 zmc_m8[23473].DB1-zm_image.cpp/285 [PopulateFrame: width 1080 height 1920 linesize 4320 colours 4 imagesize 8294400]
11/20/22 15:39:29.973008 zmc_m8[23473].DB1-zm_image.cpp/286 [Image.Populate(frame): format 26 rgba 1080x1920 linesize:4320x0 pts: -9223372036854775808 keyframe: 1]
11/20/22 15:39:29.973011 zmc_m8[23473].DB1-zm_image.cpp/315 [source frame before convert: format 12 yuvj420p 1080x1920 linesize:1152x576 pts: 935998 keyframe: 0]
11/20/22 15:39:29.976185 zmc_m8[23473].DB1-zm_image.cpp/329 [dest frame after convert: format 26 rgba 1080x1920 linesize:4320x0 pts: 935998 keyframe: 1]
11/20/22 15:39:29.976195 zmc_m8[23473].DB3-zm_monitor.cpp/2608 [Timestamping]
11/20/22 15:39:29.977006 zmc_m8[23473].DB2-zm_packetqueue.cpp/491 [waiting.  Queue size 64 it == end? 1]
11/20/22 15:39:29.977031 zmc_m8[23474].DB3-zm_packetqueue.cpp/455 [get_packet using it 0x561b1d70b8c0 locking index 125]
11/20/22 15:39:29.977042 zmc_m8[23474].DB2-zm_packetqueue.cpp/460 [Locked packet 125, unlocking packetqueue mutex]
11/20/22 15:39:29.977046 zmc_m8[23474].DB3-zm_monitor.cpp/1724 [Motion detection is enabled signal(1) signal_change(0) trigger state(Cancel) image index 125]
11/20/22 15:39:29.977049 zmc_m8[23474].DB3-zm_monitor.cpp/1730 [Have event lock]
11/20/22 15:39:29.977052 zmc_m8[23474].DB1-zm_monitor.cpp/1891 [Not Active(0) enabled 0 active 0 doing motion detection: 0]
11/20/22 15:39:29.977055 zmc_m8[23474].DB2-zm_monitor.cpp/1900 [Have event 3561 in record]
11/20/22 15:39:29.977057 zmc_m8[23474].DB1-zm_monitor.cpp/2043 [State TAPE because image_count(125)-last_alarm_count(0) > post_event_count(2) and timestamp.tv_sec(1668955169) - recording.tv_src(1668955161) >= min_section_length(10)]
11/20/22 15:39:29.977061 zmc_m8[23474].DB3-zm_packetqueue.cpp/227 [stream index 0 ?= video_stream_id 0, keyframe 0, keep_keyframes 1,  counts 64 > pre_event_count 2 at begin 1]
11/20/22 15:39:29.977070 zmc_m8[23474].DB2-zm_packetqueue.cpp/530 [Incrementing 0x561b1d70b8c0, queue size 64, end? 0]
11/20/22 15:39:29.977072 zmc_m8[23474].DB2-zm_packetqueue.cpp/540 [At end]
11/20/22 15:39:29.977075 zmc_m8[23474].DB2-zm_packetqueue.cpp/445 [waiting.  Queue size 64 it == end? 1]
11/20/22 15:39:29.977094 zmc_m8[23475].DB1-zm_event.cpp/738 [Adding packet 125]
11/20/22 15:39:29.977101 zmc_m8[23475].DB2-zm_event.cpp/348 [have_video_keyframe 1 codec_type 0 == video? 1 packet keyframe 0]
11/20/22 15:39:29.977104 zmc_m8[23475].DB2-zm_event.cpp/350 [Adding to event: pts: 935998, dts: 935998, size: 15482, stream_index: 0, flags: 0000, keyframe(0) pos: -1, duration: 7500]
11/20/22 15:39:29.977109 zmc_m8[23475].DB1-zm_videostore.cpp/1054 [Queue size for 0 is 50]
11/20/22 15:39:29.977112 zmc_m8[23475].DB1-zm_videostore.cpp/1064 [Found in order packet]
11/20/22 15:39:29.977114 zmc_m8[23475].DB1-zm_videostore.cpp/1082 [Pushing on queue 0, size is 51]
11/20/22 15:39:29.977118 zmc_m8[23475].DB2-zm_videostore.cpp/1276 [Doing passthrough, just copy packet: pts: 561598 * 1/90000=6.239978, dts: 561598, size: 24859, stream_index: 0, video flags: 0000, keyframe(0) pos: -1, duration: 7500]
11/20/22 15:39:29.977130 zmc_m8[23475].DB2-zm_videostore.cpp/1419 [finished pkt: pts: 554398 * 1/90000=6.159978, dts: 554398, size: 24859, stream_index: 0, video flags: 0000, keyframe(0) pos: -1, duration: 7500]
11/20/22 15:39:29.977134 zmc_m8[23475].DB3-zm_videostore.cpp/1420 [next_dts for stream 0 has become 561898 last_dts 554398]
11/20/22 15:39:29.977155 zmc_m8[23475].DB1-zm_event.cpp/438 [Have frame type Normal from score(0) state 5 frames 126 bulk frame interval 100 and mod26]
11/20/22 15:39:29.977158 zmc_m8[23475].DB1-zm_event.cpp/460 [Not Writing snapshot because frames 126 score 0 > max 0]
11/20/22 15:39:30.047791 zmc_m8[23471].DB2-zm_ffmpeg_camera.cpp/238 [ffmpeg_camera in: pts: 943197 * 1/90000=10.479967, dts: 943197, size: 22410, stream_index: 0, video flags: 0000, keyframe(0) pos: -1, duration: 7500]
11/20/22 15:39:30.047878 zmc_m8[23471].DB2-zm_monitor.cpp/2418 [Have packet stream_index:0 ?= videostream_id: 0 q.vpktcount 64 event? 1 image_count 126]
11/20/22 15:39:30.047883 zmc_m8[23471].DB2-zm_packetqueue.cpp/112 [packet counts for 0 is 65]
11/20/22 15:39:30.047912 zmc_m8[23473].DB3-zm_packetqueue.cpp/501 [get_packet using it 0x561b1db19e60 locking index 126]
11/20/22 15:39:30.047937 zmc_m8[23473].DB2-zm_packetqueue.cpp/506 [Locked packet 126, unlocking packetqueue mutex, incrementing it]
11/20/22 15:39:30.047956 zmc_m8[23474].DB3-zm_packetqueue.cpp/455 [get_packet using it 0x561b1d70b8c0 locking index 126]
11/20/22 15:39:30.047964 zmc_m8[23473].DB3-zm_ffmpeg.cpp/69 [nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2]
11/20/22 15:39:30.047985 zmc_m8[23474].DB2-zm_packetqueue.cpp/465 [waiting.  Queue size 65 it == end? 0]
11/20/22 15:39:30.052586 zmc_m8[23473].DB1-zm_packet.cpp/130 [got frame: format 12 yuvj420p 1080x1920 linesize:1152x576 pts: 943197 keyframe: 0]
11/20/22 15:39:30.052597 zmc_m8[23473].DB3-zm_packet.cpp/208 [Same pix format yuvj420p so not hwtransferring. sw_pix_fmt is yuvj420p]
11/20/22 15:39:30.052642 zmc_m8[23473].ERR-zm_signal.cpp/50 [Got signal 6 (Aborted), crashing]
I've seen this before... and fixed it before.. sigh.
1080 is not a multiple of 32. So ffmpeg needs a buffer that is slightly larger... and something is going wrong.
I don't have a camera that actually does rotation at the moment... so I'm having trouble setting up a test and reproducing it...
NotSoWittyName
Anything I can help with? E.g. pre-record a stream and send somewhere? Test some dev version for debug output? Anything else?
We could try a sample file... I'm a little concerned that it seems to work for a bit initially... and then crashes...
NotSoWittyName
Please let me know which data you need, how I should grab it, and where to put it. I could, e.g., upload 1080x1920 recordings (of, e.g., 2 mins) created directly by the camera?
If you make a recording, and make a monitor pointing to the file, does it crash too?
If so, then sure send me a recording to isaac@zoneminder.com
Another thing that you could try if you are adventurous is running zmc under valgrind... so let's say the affected monitor is #3.
# Stop existing process
sudo zmdc.pl stop zmc -m 3
# Run it under valgrind
sudo su -s/bin/bash -c"valgrind -v zmc -m3" www-data
# Restart original process once done
sudo zmdc.pl start zmc -m 3
Let's see what additional output we get from valgrind
NotSoWittyName
ok, created a new monitor:
General - Source Type: File
Source - Source Path: <full path and filename>
Source - Capture Resolution: 1080 x 1920
Result:
"2022/11/23 17:56:28",zmc_m9,,1920,ERR,"Failed to prime capture of initial monitor",zmc.cpp,258
"2022/11/23 17:56:19",zmc_m9,,1920,ERR,"Failed to prime capture of initial monitor",zmc.cpp,258
"2022/11/23 17:56:11",zmc_m9,,1920,ERR,"Failed to prime capture of initial monitor",zmc.cpp,258
"2022/11/23 17:56:04",zmc_m9,,1920,ERR,"Failed to prime capture of initial monitor",zmc.cpp,258
"2022/11/23 17:55:58",zmc_m9,,1920,ERR,"Failed to prime capture of initial monitor",zmc.cpp,258
"2022/11/23 17:55:53",zmc_m9,,1920,ERR,"Failed to prime capture of initial monitor",zmc.cpp,258
"2022/11/23 17:55:49",zmc_m9,,1920,ERR,"Failed to prime capture of initial monitor",zmc.cpp,258
"2022/11/23 17:55:46",zmc_m9,,1920,ERR,"Failed to prime capture of initial monitor",zmc.cpp,258
"2022/11/23 17:55:44",zmc_m9,,1920,ERR,"Failed to prime capture of initial monitor",zmc.cpp,258
"2022/11/23 17:55:43",zmc_m9,,1920,INF,"Starting Capture version 1.36.31",zmc.cpp,220
Ok, let's forget about this for now, try valgrind...
... Hm, that's too big. Please see here for the output:
https://pastebin.com/Twn7JfYT
Does this help?
I have managed to reproduce it here. I'll have it fixed soon.
Are you using 24bit colour in Source tab of monitor? If so, switch it to 32bit.
