PurgeWhenFull no longer works for my events disk
uuhi
Post by uuhi »
Hi!
After upgrading to v1.36.31 I noticed that filter PurgeWhenFull no longer works for my 6 Tb disk that is dedicated to ZM events.The disk is mounted as a "/media/zm_events" and is owned by www-data and has appropriate rights.
Actually, what happens is that the "/media/zm_events" disk fills up to 100% and then then ZM starts to fill default storage "/var/cache/zoneminder/events". As that disk reaches 95%, PurgeWhenFull removes older events so that the default storage does not get full. So, filter works ok for default strorage but not for the "/media/zm_events" disk.
I tested the PurgeWhenFull filter's "list maches" and filter finds matches in the "/media/zm_events" but for some reason does not delete them. Also filter is running:
'zmfilter.pl --filter_id=1 --daemon' running since 22/11/16 07:31:52, pid = 82690, valid
'zmfilter.pl --filter_id=2 --daemon' running since 22/11/16 00:00:23, pid = 59101, valid
The system have been working great until now. Is there something broken or am I missing something?
Edit: zmfilter_1.log
16.11.2022 00:00:24.645006 zmfilter_1[59113].INF [main:182] [Scanning for events using filter id '1']
16.11.2022 07:31:50.767234 zmfilter_1[59113].INF [main:113] [Received TERM, exiting]
16.11.2022 07:31:53.122893 zmfilter_1[82690].INF [main:182] [Scanning for events using filter id '1']
11/16/22 09:11:25.800145 zmfilter_1[97803].INF [main:182] [Scanning for events using filter id '1']
11/16/22 09:20:39.951021 zmfilter_1[97911].INF [main:182] [Scanning for events using filter id '1']
Re: PurgeWhenFull no longer works for my events disk
I'm on proposed 1.36.32, and it seems ok. Didn't notice any prob on .31, but that doesn't mean it was working... :|
Maybe post screenshot of your options-storage page and your filter. And or see if it's broke on .32
Have you pointed the filter to the 6TB storage? Look at Storage Area if not.
uuhi
Post by uuhi »
Thanks for pointing me to the right direction. For some reason in filters "Disk percent" "Greater or equal" to "95'' just did not work. I made a copy of provided filter "PurgeWhenFull" named it differently and augmented it with "and" "Storage Area" "Equal" "6TB_disk". Most importantly I changed the "Disk percent" to the "Event Disk Space". That made the difference!
In the zmfilter log I can see that it is deleting some of the oldest events. I guess it is working now although I have no clue why this chance over all has happened.
uuhi
Post by uuhi »
Still a problem. As it does not work to use "Disk percent" in the filter I use "Event disk space" instead. Now I'm in doubt what to put in the next field. Now I have left it to 95 which obviously is not correct as filter keeps removing even disk is 84%. Should it be Mbytes, Gbytes, bytes or what. I did not find any info about that. Any clue?
Event DIsk Space matches the space taken up by individual events. Put it back to just Disk Space
uuhi
Post by uuhi »
Thank you for your attention. I changed filter back to Disk Percent. Mysteriously it seems to be working now. If I test the filter by clicking "List Matches" I get no results. However, in the zmfilter_7.log I can see it actually deletes events.
Remains a mystery why filter "PurgeWhenFull" actually stopped doing its job for my event disk as I haven't done any changes to the system excluding updates. This Zm box has been running flawlessly more than a year at least...
