zoneminder- 1.36.29-focal1 , monitor status cant' be change to modect using Function[ Solved ]
bkjaya1952
Post by bkjaya1952 »
I have tested zoneminder- 1.36.29-focal1 , ( The latest release ) with USB monitor on Ubuntu focal and found the function status ( none, monitor, modect, Record, mocord, nodect ) can't be changed using the function sub menu at zm console .
But it can be changed using the Source sub menu in the zm console
Re: zoneminder- 1.36.29-focal1 , monitor status cant' be change to modect using Function
Can you please follow the proposed ppa in your testing? It contains fixes prior to release and it would be great to get more testing.
ppa:iconnor/zoneminder-proposed
Currently should have a 1.36.30 package available.
Alternatively build for the release-1.36 branch which is what the ppa is built from.
bkjaya1952
iconnor wrote: Fri Oct 14, 2022 8:01 pm Can you please follow the proposed ppa in your testing? It contains fixes prior to release and it would be great to get more testing.
Thank you Sir !
I will try and let you know
bkjaya1952
Dear Sir
Today I have tested with ppa:iconnor/zoneminder-proposed and found that the problem has been solved in proposed release
The release is zoneminder proposed 1.36.30~20221014.0-focal1
In the zm 1.36.30~20221014.0-focal1 ( proposed ) , The function status can be changed using the function sub menu itself .
Therefore I shall be thankful to you If you could replace zoneminder- 1.36.29-focal1 with propsed 1.36.30~20221014.0-focal1
Thank you
bkjaya1952
Dear Sir,
Today I have tested the latest zoneminder 1.36.31-focal1 The Memory Remains with USB monitor and found the issue has been fixed in the latest release.
Thank you very much for solving the problem !
Screenshot from 2022-10-18 22-07-17.png (348.57 KiB) Viewed 3827 times
