Motion detection visual feedback.
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
ameterasu
Post by ameterasu »
I've started to experiment with the motion detection and zone side of Zoneminder.
It would be very helpful if there was some kind of visual feedback in the zone menu.
I have cameras high at 15meters, and some look over big areas. It's very hard to do minor optimization without any feedback on where in the image is the change detected.
If possible, the pixel group can be marked? Or maybe a set sized marker at the center of the motion detected area?
I'm not even sure if it's possible.
Re: Motion detection visual feedback.
1.37 has this.
