unable to watch downloaded videso ?
david1234
Post by david1234 »
I running version 1.34.22
everything is working without any problems
I can see the video is created - I can wathc it online using the browser
when I mark the wanted video and press "Download video" it download me ~ 50Mb of mp4 file
but when I try to run it in vlc or any other video player - I get error video is not supported
I have also try to enter the video and press "Download MP4" - same file size ~ 50MB but get error when try to play it.
when I look in the file propeties there is no information in the "Details" tab :
Length is 00:00:00
Title: "Zoneminder Security Recording"
all other are empty
when I run "mediainfo' from the cmd I can see information and all seem to be correct there:
mediainfo /media/usb/3/2022-08-08/18/18-video.mp4
General
Complete name                            : /media/usb/3/2022-08-08/18/18-video.mp4
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom (isom/iso2/avc1/iso6/mp41)
File size                                : 68.0 MiB
Duration                                 : 12 min 38 s
Overall bit rate                         : 751 kb/s
Movie name                               : Zoneminder Security Recording
Writing application                      : Lavf58.20.100
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Baseline@L1
Format settings                          : 1 Ref Frames
Format settings, CABAC                   : No
Format settings, ReFrames                : 1 frame
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 717 kb/s
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Variable
Frame rate                               : 10.459 FPS
Minimum frame rate                       : 1.038 FPS
Maximum frame rate                       : 23.981 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.074
Stream size                              : 64.9 MiB (95%)
Codec configuration box                  : avcC
Audio
Format                                   : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Codec ID                                 : mp4a-40-2
Bit rate                                 : 32.9 kb/s
Channel(s)                               : 1 channel
Channel layout                           : C
Sampling rate                            : 8 000 Hz
Frame rate                               : 7.812 FPS (1024 SPF)
Compression mode                         : Lossy
Stream size                              : 2.97 MiB (4%)
Default                                  : Yes
Alternate group                          : 1
what could be the reason ? and what can I do ?
Thanks,
Re: unable to watch downloaded videso ?
You might try something else to play it. ffplay is generally good.
You should also stop using 1.34. It is very old.
