Event firing, alarm frames present, but video missing movement
MeadowCourt
Post by MeadowCourt »
Not sure what is going on here, but I've got a camera set up with the following buffer config:
2022-08-04 09_30_53-MeadowCourt - Monitor - 23 Springdale - Garage - Brave.png
2022-08-04 09_30_53-MeadowCourt - Monitor - 23 Springdale - Garage - Brave.png (13.41 KiB) Viewed 7822 times
It is correctly generating an event on movement with the shown alarm frames etc:
2022-08-04 09_32_37-MeadowCourt - Event 668617 - Brave.png (18.66 KiB) Viewed 7822 times
I can see the vehicle in the alarm frame:
2022-08-04 09_34_10-MeadowCourt - Frame - 668617 - 1 - Brave.png (410.26 KiB) Viewed 7822 times
The video shows the alarm as red in the timeline, but there is no vehicle recorded at all.
Any thoughts on what might be going here?
MeadowCourt
Re: Event firing, alarm frames present, but video missing movement
Could not attach a screenshot of video showing no vehicle in the original post, so followed up here
2022-08-04 09_41_41-ScreenToGif - Editor.png (800.54 KiB) Viewed 7821 times
Morphyx
Post by Morphyx »
I'm having the exact same problem as you had.
Did you ever manage to solve it?
Seems like the video starts a few seconds after the alarm is triggered.
These are my settings:
Also i'm using Camera passthrough
The alarm frame:
alarm frame.jpg (178.24 KiB) Viewed 7655 times
And the video missing the alarm:
You both have a crazy high ImageBufferCount, likely because your systems didn't automatically adjust it during an upgrade to 1.36. That defaults to 3 now. You might realistically set it to 5 if video playback isn't smooth. Setting it so high means your system will be using a lot of ram unnecessarily.
Please look in your logs. I am suspecting that there are complaints about dropping packets from queue and not keeping up.
Morphyx
Post by Morphyx »
The logs shows the following details during the alarm:
(above alarm event code is: 1382)
If i change the ImageBufferCount down to 3, how long will the recordings be before the alarm goes off?
I want the recording to store a few seconds before the alarm goes off, in this case 20 pre event image count with a fps of 10 gives me 2 seconds.
The documentation tells me that pre event image count should not exceed half the ring buffer size=Image Buffer Size?
