ZM stream freeze after X hours
phuongpham
Post by phuongpham »
Hi
I'm using openHAB and use the habpanel module.
With this module I can show different "panel"
Some of the panel just show the ZM stream.
It has worked fine for a long time but since upgrading ZM to 1.36? I have problem that the streaming from ZM freeze after couple of hours.
The URL i'm using for the streaming is:
https://zm.url/zm/cgi-bin/nph-zms?mode= ... ss=xxxxxxx
Re: ZM stream freeze after X hours
Hmmm... can't think of any reason for it to die after hours... but really... it can break. openhab should just reload it. You might consider removing the buffer= from the url to reduce load on your server.
