New PPA for Ubuntu 22.04 jammy jellyfish?
smithjw1
Post by smithjw1 »
Will there be a PPA for Ubuntu 22.04 jammy jellyfish? I'm currently on the Beta with zoneminder 1.36.12 and it is having some difficulties with PHP 8.1.
Re: New PPA for Ubuntu jammy jellyfish?
It will happen when it happens!
I am glad you have the time to experiment with beta versions. In my opinion Ubuntu has become a pain and I seem to get better performance with Debian.
smithjw1
Re: New PPA for Ubuntu 22.04 jammy jellyfish?
Post by smithjw1 »
Ubuntu 22.04 has now officially been released on 4/21. This is a long term release that replaces 20.04. Do we have a zoneminder release that will support 22.04? I'm currently on 1.36 but it has some problems on 22.04. What should I be running? 1.37 maybe?
I would stay on 1.36 unless you like the bleeding edge and things not working.
If you look on Slack you can see Isaac is looking at this. I’ll be holding on 20.04 for a while yet.
smithjw1
Post by smithjw1 »
I'm currently on 1.36.12, but it will not update past this level because of PHP8.1. Even on 1.36.12 I get errors about functions that have been deprecated. If I try to manually update to 1.36.14, I get The following packages have unmet dependencies:
zoneminder : Depends: php-apc but it is not installable or
php-apcu-bc but it is not installable
That is why I was looking for a repository for the new Ubuntu release.
There is currently no working build.
smithjw1
Post by smithjw1 »
PPA for ubuntu 22.04 jammy is now working. Thank you.
harrisonland
Post by harrisonland »
Having stupidly just done an "upgrade" without checking everything was going to be OK I found that 1.36.x no longer worked in Ubuntu 22.04 .
I now find that all's well again now the jellyfish PPA has been updated. Massive thanks to @iconnor for the work, It's much appreciated.
I know this isn't necessarily the right place to mention this, but if you're using zmeventserver you may need to re-install the perl dependencies
with
sudo perl -MCPAN -e "install Crypt::MySQL"
sudo perl -MCPAN -e "install Config::IniFiles"
sudo perl -MCPAN -e "install Crypt::Eksblowfish::Bcrypt"
to have the event server working again. Happened to me, so mentioned here for anyone left scratching their heads!
Tim
RonRN18
Post by RonRN18 »
Crap! I decided to perform an in-place upgrade (do-release-upgrade) to upgrade from Ubuntu 21.10 to 22.04, and after re-enabling the repositories, I can no longer access my web interface. It appears to have started but I can't access it. I checked the status of the zoneminder.service.
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
     Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
     Active: active (running) since Wed 2022-05-18 17:53:52 PDT; 1min 56s ago
    Process: 15727 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
   Main PID: 15742 (zmdc.pl)
      Tasks: 134 (limit: 38251)
     Memory: 12.8G
        CPU: 5min 18.417s
     CGroup: /system.slice/zoneminder.service
             ├─15742 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
             ├─15771 /usr/bin/zmc -m 1
             ├─15776 /usr/bin/zmc -m 2
             ├─15781 /usr/bin/zmc -m 3
             ├─15786 /usr/bin/zmc -m 4
             ├─15791 /usr/bin/zmc -m 5
             ├─15796 /usr/bin/zmc -m 6
             ├─15801 /usr/bin/zmc -m 7
             ├─15807 /usr/bin/zmc -m 8
             ├─15812 /usr/bin/zmc -m 9
             ├─15817 /usr/bin/zmc -m 10
             ├─15822 /usr/bin/zmc -m 11
             ├─15827 /usr/bin/zmc -m 12
             ├─15832 /usr/bin/zmc -m 13
             ├─15837 /usr/bin/zmc -m 14
             ├─15842 /usr/bin/zmc -m 15
             ├─15847 /usr/bin/zmc -m 16
             ├─15852 /usr/bin/zmc -m 17
             ├─15857 /usr/bin/zmc -m 18
             ├─15862 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
             ├─15867 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
             ├─15873 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=7 --daemon
             ├─15878 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
             ├─15883 /usr/bin/perl -wT /usr/bin/zmwatch.pl
             ├─15888 /usr/bin/perl -wT /usr/bin/zmupdate.pl -c
             └─15892 /usr/bin/perl -wT /usr/bin/zmstats.pl
May 18 17:53:52 zm sudo[15879]:     root : PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl start zmwatch.pl
May 18 17:53:52 zm sudo[15879]: pam_unix(sudo:session): session opened for user www-data(uid=33) by (uid=0)
May 18 17:53:52 zm sudo[15879]: pam_unix(sudo:session): session closed for user www-data
May 18 17:53:52 zm sudo[15884]:     root : PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl start zmupdate.pl -c
May 18 17:53:52 zm sudo[15884]: pam_unix(sudo:session): session opened for user www-data(uid=33) by (uid=0)
May 18 17:53:52 zm sudo[15884]: pam_unix(sudo:session): session closed for user www-data
May 18 17:53:52 zm sudo[15889]:     root : PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl start zmstats.pl
May 18 17:53:52 zm sudo[15889]: pam_unix(sudo:session): session opened for user www-data(uid=33) by (uid=0)
May 18 17:53:52 zm sudo[15889]: pam_unix(sudo:session): session closed for user www-data
May 18 17:53:52 zm systemd[1]: Started ZoneMinder CCTV recording and surveillance system.
How can I get my web interface back?
Verify database and apache are running.
RonRN18
Post by RonRN18 »
I'm not seeing anything that looks to be an error to me...
● mariadb.service - MariaDB 10.6.7 database server
     Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
     Active: active (running) since Wed 2022-05-18 21:21:12 PDT; 37s ago
       Docs: man:mariadbd(8)
             https://mariadb.com/kb/en/library/systemd/
    Process: 202892 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
    Process: 202893 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
    Process: 202896 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $? -eq 0 ]   && systemctl set-environment _WSREP_START_POSITION=$VAR || exit 1 (code=exited, status=0/SUCCESS)
    Process: 203035 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
    Process: 203037 ExecStartPost=/etc/mysql/debian-start (code=exited, status=0/SUCCESS)
   Main PID: 202988 (mariadbd)
     Status: "Taking your SQL requests now..."
      Tasks: 69 (limit: 38251)
     Memory: 429.7M
        CPU: 1.073s
     CGroup: /system.slice/mariadb.service
             └─202988 /usr/sbin/mariadbd
May 18 21:21:12 zm systemd[1]: Starting MariaDB 10.6.7 database server...
May 18 21:21:12 zm mariadbd[202988]: 2022-05-18 21:21:12 0 [Note] /usr/sbin/mariadbd (server 10.6.7-MariaDB-2ubuntu1) starting as process 202988 ...
May 18 21:21:12 zm systemd[1]: Started MariaDB 10.6.7 database server.
● apache2.service - The Apache HTTP Server
     Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
     Active: active (running) since Wed 2022-05-18 21:23:13 PDT; 17s ago
       Docs: https://httpd.apache.org/docs/2.4/
    Process: 203380 ExecStart=/usr/sbin/apachectl start (code=exited, status=0/SUCCESS)
   Main PID: 203384 (apache2)
      Tasks: 7 (limit: 38251)
     Memory: 7.1M
        CPU: 29ms
     CGroup: /system.slice/apache2.service
             ├─203384 /usr/sbin/apache2 -k start
             ├─203385 /usr/sbin/apache2 -k start
             ├─203386 /usr/sbin/apache2 -k start
             ├─203387 /usr/sbin/apache2 -k start
             ├─203388 /usr/sbin/apache2 -k start
             ├─203389 /usr/sbin/apache2 -k start
             └─203390 /usr/sbin/apache2 -k start
May 18 21:23:13 zm systemd[1]: Starting The Apache HTTP Server...
May 18 21:23:13 zm systemd[1]: Started The Apache HTTP Server.
I'm currently stumped. So far, everything I've thought to check appears normal, yet I can't see anything when I go to the web interface.
Just focus on Apache, as you don’t need ZM to see the web interface. What do you get when you visit the page?
RonRN18
Post by RonRN18 »
I have a feeling that the problem is somehow in the Apache2 setup but can't quite put my finger on it. I was looking through my /var/log/apache2/error.log and it is full of errors. I have done a little "sanitizing" to the log and just showing a snippet, but here is some of the log file that I hope someone could explain why I'm seeing.
[:26:27.614692 2022] [cgi:error] [pid 800831] [client <router-ip>:65493] AH02811: script not found or unable to stat: /usr/lib/cgi-bin/nph-zms
[:26:27.614838 2022] [cgi:error] [pid 800832] [client <router-ip>:65492] AH02811: script not found or unable to stat: /usr/lib/cgi-bin/nph-zms
[:26:27.615274 2022] [cgi:error] [pid 800833] [client <router-ip>:65499] AH02811: script not found or unable to stat: /usr/lib/cgi-bin/nph-zms
[:26:27.615416 2022] [cgi:error] [pid 800834] [client <router-ip>:65500] AH02811: script not found or unable to stat: /usr/lib/cgi-bin/nph-zms
[:26:27.615790 2022] [cgi:error] [pid 800836] [client <router-ip>:65503] AH02811: script not found or unable to stat: /usr/lib/cgi-bin/nph-zms
[:26:32.597999 2022] [proxy:error] [pid 800981] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php8.0-fpm.sock (*) failed
[:26:32.598021 2022] [proxy_fcgi:error] [pid 800981] [client <router-ip>:1105] AH01079: failed to make connection to backend: httpd-UDS
[:26:32.690192 2022] [cgi:error] [pid 800983] [client <router-ip>:1109] AH02811: script not found or unable to stat: /usr/lib/cgi-bin/nph-zms
NOTES: While the timestamp is likely irrelevant, I trimmed away the day of the week, month, date, and hour to reduce the line width a bit.... I could have probably trimmed the entire thing. I was seeing my router's LAN address and changed it to just say <router-ip>.
Is nph-zms at /usr/lib/cgi-bin/nph-zms?
Or is it at /usr/lib/zoneminder/cgi-bin/nph-zms?
RonRN18
Post by RonRN18 »
dougmccrary wrote: Fri May 20, 2022 9:03 am Is nph-zms at /usr/lib/cgi-bin/nph-zms?
Thanks for bearing with me as I traveled down the wormhole trying to figure out what went wrong.
As to the question of "nph-zms", I saw that the file did not exist in /usr/lib/cgi-bin/ but it did existed as a symbolic link in /usr/lib/zoneminder/cgi-bin/, linking to a file in the same folder called "zms". Not knowing if it was supposed to be in /usr/lib/cgi-bin, I created another symbolic link in that folder, again pointing to "zms" in /usr/lib/zoneminder/cgi-bin/.
This didn't immediately fix anything, so I knew the main problem lay elsewhere. I again looked through the /var/log/apache2/error.log and noticed the following:
[proxy:error] [pid 1454265] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php8.0-fpm.sock (*)
I decided to look up what was in "/run/php" and noticed that it only referred to php8.1, nothing with php8.0. That is when it dawned on me what the issue was. Upon upgrading from 21.10 to 22.04, PHP had changed from PHP8.0 to PHP8.1 but when I looked in my /etc/apache2/conf-available/ folder, I saw both "php8.0-fpm.conf" and "php8.1-fpm.conf". In /etc/apache2/conf-enabled/ I saw "php8.0-fpm.conf". This was the heart of the problem. I fixed it by the following:
sudo a2disconf php8.0-fpm.conf
sudo a2enconf php8.1-fpm.conf
sudo systemctl reload apache2
Now, the web interface is working well. Zoneminder has been working in the background, recording activities, it just couldn't be accessed via the web interface; now it can. I'm not a complete idiot, just sometimes I need nudges in the right direction. I'm hoping that if anyone else has this problem, they will have an easier time finding the problem now.
