Page 1 of 1
Zoneminder master 1.37.10~20220124093136-focal can't create USB camera monitor[Solved]
Posted: Tue Jan 25, 2022 6:49 pm
by bkjaya1952
I have tested the Zoneminder master 1.37.10~20220124093136-focal , the latest release , with a USB camera today and found the following difficulties
1.The USB Camera monitor can't be created .
2. The Error logging is nit working
3. In the filters ,you can't add conditions by pressing + button
some screenshots are given below
- The USB Camera monitor can't be created
- 1.png (234.44 KiB) Viewed 17358 times
- The Error logging is nit working
- 2.png (195.51 KiB) Viewed 17358 times
- In the filters ,you can't add conditions by pressing + button
- 3.png (247.09 KiB) Viewed 17358 times
Re: Zoneminder master 1.37.10~20220124093136-focal can't create USB camera monitor
Posted: Wed Jan 26, 2022 6:32 am
by dougmccrary
Works here on my system, FYI.
Posted: Wed Jan 26, 2022 3:39 pm
by bkjaya1952
dougmccrary wrote: ↑Wed Jan 26, 2022 6:32 am
Hi dougmccrary
My test was on a fresh install . Not an upgrade.
Posted: Fri Jan 28, 2022 9:46 am
by bkjaya1952
Still the same problems prevail in Zoneminder-master latest 1.37.10~20220126213942 -focal as well
Posted: Fri Jan 28, 2022 6:26 pm
by iconnor
Please check javascript console for errors.
Posted: Sat Jan 29, 2022 1:14 pm
by bkjaya1952
iconnor wrote: ↑Fri Jan 28, 2022 6:26 pm
- Screenshot from 2022-01-29 22-34-06.png (128.27 KiB) Viewed 17243 times
Posted: Sun Jan 30, 2022 5:30 pm
by iconnor
None of those are related to ZM.
How about view page source and look for php errors in the javascript code at the bottom?
Posted: Tue Feb 01, 2022 9:18 am
by bkjaya1952
iconnor wrote: ↑Sun Jan 30, 2022 5:30 pm
- Screenshot from 2022-02-01 14-43-05.png (96.65 KiB) Viewed 17194 times
For the latest of Zonemider master 1.37.10~20220131141528-focal released today
Figure:- 1 .Page source -of monitor page
- Screenshot from 2022-02-01 14-34-38.png (436.82 KiB) Viewed 17194 times
Figure:- 2 javascript console
Posted: Tue Feb 01, 2022 3:11 pm
by iconnor
Some config entry has a new line in it.
Try latest build which escapes them.
Posted: Wed Feb 02, 2022 7:22 pm
by bkjaya1952
iconnor wrote: ↑Tue Feb 01, 2022 3:11 pm
Thank you very much Sir
I have tested the latest Zoneminder-master with Ubuntu impish , bionic and focal
The problem has been solved in the latest Zoneminder-master latest 1.37.10~20220201140734-impish & bionic
There is a small problem in installing Zoneminder Zoneminder-master latest 1.37.10~20220201140734-focal as there is a dependency issue.
(the following packages have unmet dependencies: software-properties-common : depends: gir1.2-glib-2.0 but it is not installable depends: gir1.2-packagekitglib-1.0 (>= 1.1.0-2) but it is not going to be installed depends: packagekit but it is not going to be installed depends: python3 but it is not installable depends: python3-dbus but it is not installable depends: python3-gi but it is not installable depends: python3-requests-unixsocket but it is not installable depends: python3-software-properties (= 0.98.9.2) but it is not going to be installed depends: python3:any but it is not installable )
Posted: Thu Feb 03, 2022 2:03 am
by iconnor
That's weird. We havn't really altered the dependencies much in a long time.
Further it is saying that it can't install python3. That's kindof a major package.
Posted: Thu Feb 03, 2022 2:22 pm
by bkjaya1952
iconnor wrote: ↑Thu Feb 03, 2022 2:03 am
Thank you very much Sir !
The above problem has been solved in the latest Zoneminder-master 1.37.11~20220202205903-focal released today!
- Screenshot from 2022-02-03 19-48-08.png (297.55 KiB) Viewed 17115 times
