Zoneminder master 1.37.10~20220124093136-focal can't create USB camera monitor[Solved]
bkjaya1952
Post by bkjaya1952 »
I have tested the Zoneminder master 1.37.10~20220124093136-focal , the latest release , with a USB camera today and found the following difficulties
1.The USB Camera monitor can't be created .
2. The Error logging is nit working
3. In the filters ,you can't add conditions by pressing + button
some screenshots are given below
Re: Zoneminder master 1.37.10~20220124093136-focal can't create USB camera monitor
Works here on my system, FYI.
bkjaya1952
dougmccrary wrote: Wed Jan 26, 2022 6:32 am
Hi dougmccrary
My test was on a fresh install . Not an upgrade.
bkjaya1952
Still the same problems prevail in Zoneminder-master latest 1.37.10~20220126213942 -focal as well
Please check javascript console for errors.
bkjaya1952
iconnor wrote: Fri Jan 28, 2022 6:26 pm Please check javascript console for errors.
Screenshot from 2022-01-29 22-34-06.png (128.27 KiB) Viewed 18537 times
None of those are related to ZM.
How about view page source and look for php errors in the javascript code at the bottom?
bkjaya1952
iconnor wrote: Sun Jan 30, 2022 5:30 pm None of those are related to ZM.
Screenshot from 2022-02-01 14-43-05.png (96.65 KiB) Viewed 18488 times
For the latest of Zonemider master 1.37.10~20220131141528-focal released today
Figure:- 1 .Page source -of monitor page
Screenshot from 2022-02-01 14-34-38.png (436.82 KiB) Viewed 18488 times
Figure:- 2 javascript console
Some config entry has a new line in it.
Try latest build which escapes them.
bkjaya1952
iconnor wrote: Tue Feb 01, 2022 3:11 pm Some config entry has a new line in it.
Thank you very much Sir
I have tested the latest Zoneminder-master with Ubuntu impish , bionic and focal
The problem has been solved in the latest Zoneminder-master latest 1.37.10~20220201140734-impish & bionic
There is a small problem in installing Zoneminder Zoneminder-master latest 1.37.10~20220201140734-focal as there is a dependency issue.
(the following packages have unmet dependencies: software-properties-common : depends: gir1.2-glib-2.0 but it is not installable depends: gir1.2-packagekitglib-1.0 (>= 1.1.0-2) but it is not going to be installed depends: packagekit but it is not going to be installed depends: python3 but it is not installable depends: python3-dbus but it is not installable depends: python3-gi but it is not installable depends: python3-requests-unixsocket but it is not installable depends: python3-software-properties (= 0.98.9.2) but it is not going to be installed depends: python3:any but it is not installable )
That's weird. We havn't really altered the dependencies much in a long time.
Further it is saying that it can't install python3. That's kindof a major package.
bkjaya1952
iconnor wrote: Thu Feb 03, 2022 2:03 am That's weird. We havn't really altered the dependencies much in a long time.
Thank you very much Sir !
The above problem has been solved in the latest Zoneminder-master 1.37.11~20220202205903-focal released today!
Screenshot from 2022-02-03 19-48-08.png (297.55 KiB) Viewed 18409 times
