How to upgrade zoneminder ?
david1234
Post by david1234 »
I'm running zonminder on my PI4 (did the installation as it say in the zoneminder Wiki)
the version is 1.32.3
do I need to upgrade it ?
how do I upgrdae it ?
and if I upgrade it - will it save all the configuration ? or I will need to setup everything again ?
Thanks ,
Re: How to upgrade zoneminder ?
Not if it's working for you. There are some pretty cool new features, though.
Change your source from zoneminder-1.32/whatever to zoneminder-1.34 or 1.36
Usually, yes, so no.
But it's a good idea not to jump directly from 1.32 to 1.36. 1.32 to 1.34 to 1.36 is less chancy.
You probably want to save your database, just in case.
david1234
Post by david1234 »
OK
alsmost everything is working for me - I mange to get 100% of what i want\need.
so I prefer not to touch it - if it's not broken no need to fix :-)
thank you for the explain and answer
Egg-zactly.
pimehexon
Post by pimehexon »
dougmccrary wrote: Sun Dec 19, 2021 9:28 am do I need to upgrade it ?
What should I do if I upgraded zoneminder and lost all my data? Is there any way to resrore all configurations and cancel changes?
Restore/cancel
Depends on what happened. Unless you really need whatever data was lost, probably best to just forget it and forge on.
Settings are quite a bit improved just using ffmpeg and auto in most cases.
