Hello
I installed zoneminder 1.36.12 on ubuntu 20.04.3 with Isaac Connor's PPA packages.
I managed to install 6 cameras, such as "camera passthrogh" and configured it not to save JPEGS, and in the default Storage area.
I configured the monitor as a record and the events are being generated.
The problem is that I can't watch or download the events, when I open the event I get the message:
Event was not found at /var/cache/zoneminder/events/1/2021-12-15/7. It is unlikely that playback will be possible.
But the video files exist in the file system and are not corrupted.
Does anybody know how to solve this?
Event was not found at /var/cache/zoneminder/events/1/*
Lawrence Waclawiak
Re: Event was not found at /var/cache/zoneminder/events/1/*
maybe a time zone issue?
Also check ownership and permissions allow your web user (www-data) to access those files.
Thank you very much, you were right.
I added the timezone in php.ini and the problem was fixed.
Thank you very much.
Lawrence Waclawiak
