Axis 215 PTZ - problem controlling camera (Axis API v2)
agony
Post by agony »
i'm running ZoneMinder v1.36.11 on AlmaLinux and i've got a problem trying to control the camera in the topic.
Feed works ok with Ffmpeg and rtsp: protocol, but when i try to move the camera nothing happens and i get an error.
Configuration as follow:
Controllable: Checked
Control Type: Axis API v2
Control Address: user:password@x.x.x.x
running a tcpdump gives the following error:
GET //axis-cgi/com/ptz.cgi?rpan=65 HTTP/1.1
g+2"..X.GET //axis-cgi/com/ptz.cgi?rpan=65 HTTP/1.1
        Your client does not have permission to get URL /axis-cgi/com/ptz.cgi from this server.
issuing the command:
 user:password@x.x.x.x//axis-cgi/com/ptz.cgi?rpan=65
moves the camera with no error:
g,h...w.GET //axis-cgi/com/ptz.cgi?rpan=65 HTTP/1.1
any toughts?
Thanks.
alabamatoy
Re: Axis 215 PTZ - problem controlling camera (Axis API v2)
Post by alabamatoy »
May need to TS the code in Axis API v2. Its in file "AxisV2.pm" under /usr/share/perl5/ZoneMinder/Control on my Ubuntu.
Turn on debug*, restart ZM, open live view and poke at PTZ, stop debug, restart ZM, and look at logs. It should show you what's happening in detail. Post up here and we will try to assist.
If you find a problem in the control script (AxisV2.pm) please post an issue in Git so we can get it fixed for everyone in subsequent release.
* - options, logging, set:
LOG_DEBUG: checked
LOG_DEBUG_TARGET: _zmcontrol_[monitorID of camera to be PTZed] as in _zmcontrol_5
LOG_DEBUG_LEVEL: 9
Uncheck log_debug and restart after testing or you will clobber your server with voluminous logs
HTH
So yeah I have some Axis 215's. So I checked to see if PTZ still works. It doesn't.
I have fixed it in master, and the fix will be in 1.36.13. In the meantime you can grab the AxisV2.pm from master and drop it in place.
https://github.com/ZoneMinder/zoneminde ... /AxisV2.pm
In addition, this new version does not require you to populate ControlAddress. It will pull the required info from the Path on the Source tab.
owensr
Post by owensr »
Posting on this topic as sounds like the poster can answer my question!
I just upgrade from 1.32 (I think) to 1.36.12 and having issues with getting images from 2 Axis 215 PTZ cameras!
They were working fine on 1.32 so guessing the config has not come across correctly?
I have:
Protocol: RTSP
Method: RTP/RTSP
Hostname: user:password@ip.address
Port: 554
Path: /mpeg4/media.amp
Target colorspace: 32 bit colour
Capture Resolution: 704 / 576 / 704x576 D1 PAL
Preseve Aspect Ratio: unticked
Orientation: Normal
Deinterlacing: Disabled
Use RTSP Response Medai URL: unticked.
owensr
Post by owensr »
OK - found a solution:
Protocol: HTTP
Method: Simple
Port: 80
Path /mjpg/video.mjpg
But is this the best/most efficient?
Also bit odd old config has stopped working on this new release?
agony
Post by agony »
iconnor wrote: Tue Dec 14, 2021 3:07 pm So yeah I have some Axis 215's. So I checked to see if PTZ still works. It doesn't.
Thanks, now it seems to work without any problem, i'll let you know if something arises from the people using the cameras.
agony
Post by agony »
owensr wrote: Tue Dec 14, 2021 5:56 pm But is this the best/most efficient?
I use:
Source Type: Ffmpeg
Source Path: rtsp://user:password@IP/mpeg4/media.amp
Method: TCP
