Adding one reolink breaks zm
BobLaske
Post by BobLaske »
I bought a reolink E1 Outdoor (https://smile.amazon.com/gp/product/B08QVDFW27) to go with some other cameras but every time I add this camera, it breaks ZM.
By break, I mean that it has all kinds of problems like losing access to the database, crashing to the point where I have to restart the server over and over until it finally comes back up.
I haven't had the opportunity to look through the logs yet but what could cause such problems and what should I be looking for to figure that out?
Re: Adding one reolink breaks zm
Try it without the other cameras.
Sounds like you are pushing some resource beyond it's limits. Could be space in /dev/shm, could be db connection limits, could be general limited ram/cpu.
BobLaske
Post by BobLaske »
Good call.
Yes, I'm pushing the heck out of it, ZM is running on a Rockchip RK3288 Tiny ARM Single Board Computer with 2GB RAM.
Just trying to see how many cameras I can run on this little chip.
I have 5 cameras already configured, one inactive, between 600/700KB/s, load between 2-5. That works fine until I add this other camera then everything breaks.
So you think it's a simple as that uh?
Maybe I need to lower the resolution's since I'm using full stream's. I wonder if that would work.
Acewiza
Post by Acewiza »
I believe the problem is Reolink simply does not play well with Zoneminder (for whatever ACTUAL reason). I squelched mine down to very minimal frame rates/colorspace h.264 profiles, etc. - anything to lower the load on the system, until I had 11 cams idling along in modect not even breaking a sweat on the system resource load, and the Reolinks STILL suck. Hikvisions running much higher frame rates, never a glitch. Reolinks - garbage display at anything more than minimal settings.
