Upgrade to 1.36.8 can't download video or events - nothing in log
texastexas
Post by texastexas »
I moved to 1.36.8 to solve a dropped frame issue (it worked).
Now when I try to download video or an event, nothing happens. At first, there were broken pipes and I re-enabled OPT_FFMPEG, now nothing happens when I try to download a video, nothing in the log...
Same thing when I try to export an event.
texastexas
Re: Upgrade to 1.36.8 can't download video or events - nothing in log
I did a fresh install of 1.36.8 and most of the problem is gone.
I can download Events, no problem.
With videos, I get a folder when hit download, however there's no video inside the folder. I re-enabled OPT_FFMPEG, but no luck.
In master I'm reviewing the export code... made some fixes already but havn't identified the main issue.
It always just works for me.
