1.36.7 no montage
1.36.7 no montage
I seem to have lost montage view in 1.36.7. Montage Review works, but not montage. Has anyone else seen this issue?
Re: 1.36.7 no montage
Not me. I'm on ubuntu. You?
Yup, Ubuntu 20.04. Weird.
I set up a fresh Ubuntu 20.04 server yesterday with ZM 1.36.7. Montage works here but I had to set AUTH_RELAY to Plain on prior test setups. Hashed seems to work now.
Just upgraded another Ubuntu 20.04 system from 1.36.5 to 1.36.7, and same thing. I get a FPS display, but no images in montage view.
Check javascript console for errors.
Duh, of course. Not used to web dev stuff.
I get a bunch of these errors:
Request Failed: timeout, timeout skins_classic_js_skin-dark-1631560365.js:773:11
Ajax request failed. No responseText. jqxhr follows: skins_classic_js_skin-dark-1631560365.js:775:13
Object { readyState: 0, getResponseHeader: getResponseHeader(e), getAllResponseHeaders: getAllResponseHeaders(), setRequestHeader: setRequestHeader(e, t), overrideMimeType: overrideMimeType(e), statusCode: statusCode(e), abort: abort(e), state: state(), always: always(), catch: catch(e), … }
Am I the only one seeing this issue? Any ideas on what to fix?
Yes you are the only one seeing this.
You posted a snippet of logs, but not the complete logs. Really the first few errors are the most important.
you seem to have a group selected. What happens if you don't?
Same thing. I wish I could be more helpful.
I have the fix. You can set a fixed width for the cams or modify /usr/share/zoneminder/www/skins/classic/views/montage.php at line 234 to be
$monitor_options['width'] = $monitor_options['width']?$monitor_options['width'].'px' : null;
I will try to release 1.36.8 today with this and a couple other fixes.
Thank you very much!
1.36.8 fixed it for me. Again, thank you!
