New install RPi - `'zmc -m 1' exits abnormally when camera defined
scheen
Post by scheen »
Hi All
I'm new the ZM...
Installed for the first time ZM 1.36 on RPi 4b 8GB with 480GB SSD according to the latest Debian guide https://wiki.zoneminder.com/Debian_10_B ... om_ZM_Repo
Install worked fine.
I have one camera (TP-Link Tapo TC70). I can stream with ffmpeg on the CMDL with `ffmpeg -i "rtsp://user:pass@192.168.xxx.xxx:554/stream1" out.mp4` without problems.
However, in ZM, when I add the camera in the Console as an FFMPEG device, leaving everything empty expect for the Source path to `rtsp://user:pass@192.168.xxx.xxx:554/stream1` and setting resolution to 1920x1080, then
I get an error in the logs `'zmc -m 1' exited abnormally, exit status 255`. ZM is also not able to stream from the camera.
How can I debug this further, to understand what is going on? Or maybe someone has the cure to this right away?
Many thanks
S
burger
Re: New install RPi - `'zmc -m 1' exits abnormally when camera defined
Post by burger »
RPI may not be able to do 1920x1080. Try lowering the resolution / framerate.
It's not just recording a video, it's also trying to do motion detection (mathematical analysis of the stream) which
requires a powerful CPU.
See this page:
https://wiki.zoneminder.com/Single_Board_Computers
fastest way to test streams:
scheen
Post by scheen »
Thank you for the suggestion.
I changed it to 640x360 and monitor only.
Sadly, that still fails - however with a different error message:
'zmc -m 2' exited abnormally, exit status 255
What else can I do to get more useful error output?
Turn on debug logs. Options->Logging->ZM_DEBUG.
