Problems installing 1.34 on Debian Buster
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
jonatha
Post by jonatha »
Installed Debian Buster from scratch.
Followed the instructions for Buster at https://zoneminder.readthedocs.io/en/la ... ebian.html (more or less - didn't install mySQL in the hopes that the already-installed mariadb would suffice).
sudo apt install zoneminder barfs quite voluminously:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
zoneminder : Depends: libjwt-gnutls0 (>= 1.9.0) but it is not installable
Depends: libjs-mootools (>= 1.4.5~debian1) but it is not installable
Depends: ffmpeg but it is not going to be installed or
libav-tools but it is not installable
Depends: libdate-manip-perl but it is not installable
Depends: libmime-lite-perl but it is not installable
Depends: libmime-tools-perl but it is not installable
Depends: libdbd-mysql-perl but it is not installable
Depends: libphp-serialization-perl but it is not installable
Depends: libnet-sftp-foreign-perl but it is not installable
etc. etc.
jonatha
Re: Problems installing 1.34 on Debian Buster
Post by jonatha »
I neglected to mention that I am using backports (needed the Intel 630 driver) and so am running a 5.x kernel etc. In the absence of anything else obvious, I will assume that is causing the issue.
I wonder if switching to 1.36 would help...
jonatha wrote: Wed Jul 07, 2021 5:44 am I neglected to mention that I am using backports (needed the Intel 630 driver) and so am running a 5.x kernel etc. In the absence of anything else obvious, I will assume that is causing the issue.
https://wiki.zoneminder.com/Debian_10_B ... om_ZM_Repo
