[SOLVED] Multi-Server no thumbnails if not loged in to all servers
andrewhack
Post by andrewhack »
Hi everyone,
I have multi-server setup running 1.34.25.
User authentication is enabled and when I am logged in to all servers I can see the event thumbnails of the events generated from other servers.
If I am not logged in to a specifics server the thumbnails are not visible.
No issues with the events it self - playable in all cases
Any suggestions? :roll:
Re: Multi-Server no thumbnails if not loged in to all servers
You need some sort of AUTH_RELAY. Probably AUTH_HASH. Check settings under Options->System.
andrewhack
Yes, thank you
AUTH_HASH_LOGINS is required
