Released 1.36.4 The Memory Remains
Information and announcements regarding the website and forums in general.
Changes since 1.36.3
- Fix revision of CRUD in submodule
- Fix problems in zmstats.pl: Fix log deletion only ever deleting 100 entries when it should delete more in a loop. Add deleting more than 100 sessions. Fix loop not terminating on Ctrl-C
- Add samesite when setting cookie for skin and css
- Default to UTC when no timezone set so that montagereview continues working. Fixes #3274
- Fix bug in onvifprobe when specifying interface
- Remove 25x and 50x rate options in event view. Browsers do not support them. Add 16x which is the max. Fixes #3284
- fix crash when in alert state with no event
- fix some queue clearing cases that cause hangs
- improve efficiency of getting packets from queue in decode thread.
- fix timestamping not being done on all recorded frames
- Fix renaming events #3265
1.36.4
Full Changelog
