time setting
titof2375
time setting
Post by titof2375 »
hello how do we set the time in zoneminder
heure chez moi 1.PNG (94.43 KiB) Viewed 3310 times
and at my house it is 6 a.m.
reglage chez moi.PNG (12.9 KiB) Viewed 3310 times
alabamatoy
Re: time setting
Post by alabamatoy »
It just uses the CPU time / date, I believe.
titof2375
Re: time setting
Post by titof2375 »
yes, except that on the camera it is 4 o'clock while it is 6 o'clock
bkjaya1952
Re: time setting
Post by bkjaya1952 »
Methods to edit area and timezone
sudo gedit /etc/php/7.4/apache2/php.ini
Then edit line no 962 with your time zone
date.timezone =
sudo gedit /etc/timezone
Then edit your timezone
sudo dpkg-reconfigure tzdata
Then select your area and timezone
Goto zoneminder panel &
Options > timezone > & select your timezone and save
alabamatoy
Re: time setting
bkjaya1952 wrote: Tue Apr 20, 2021 6:48 pm Methods to edit area and timezone
Thanks, good info. Might oughta be in the ZM docs?
titof2375
Re: time setting
Post by titof2375 »
Hello, I found for my zoneminder time difference problem, it came from my proxmox Lxc container which was not in the correct time zone
