update to 1.34 coming from 1.29
e-gund
Post by e-gund »
I´m running Debian Buster with ZM 1.29 and would like to update to 1.34. The Wiki means i should look into the Forum for further information. But i could not find anything specialy for my update. In general, is it good idea to do a straight update to 1.34? Is there anything I should know before, something special to take care for?
Thank you.
Re: update to 1.34 coming from 1.29
Would be a good idea to take a dump (backup) of the zm database before doing the backup.
This should work for upgrade:
Edit the sources.list
sudo nano /etc/apt/sources.list
Remove any old entries to the Zoneminder packages
Add the following line to the end of the file
deb https://zmrepo.zoneminder.com/debian/release-1.34 buster/
CTRL+o then [Enter] to save
CTRL+x to exit
Install the following and retrieve the key from the repro
sudo apt install apt-transport-https gnupg
wget -O - https://zmrepo.zoneminder.com/debian/ar ... eyring.gpg | sudo apt-key add -
Important - Make sure the above "wget" process completes without error! If it does not complete you will not get the most recent Zoneminder version this procedure is written for.
sudo apt update
sudo apt upgrade
Should do it!
e-gund
Post by e-gund »
i finaly got it running. But i run in some issues. For reference here is what i had to do:
I got the error
Database successfully upgraded to version 1.31.18.
Upgrading DB to 1.31.19 from 1.29.0
ERROR 1419 (HY000) at line 21: You do not have the SUPER privilege and binary logging is enabled (you *might* want to use the less safe log_bin_trust_function_creators variable)
to solve this i had to
mysql -u USERNAME -p
set global log_bin_trust_function_creators=1;
exit
and run the updater again with
zmupdate.pl
now the updater ran thought the complete process and i could login in the webinterface. unfortunately all symbols where missing and the layout was not as it should. I found out there was a symlink missing at
/usr/share/zoneminder/www/cache
pointing to
/var/cache/zoneminder/cache
After creating a symlink i had to restart apache with
 /etc/init.d/apache2 restart
and it worked.
thank you.
