User Authentication is not turned on
kdmiller45
Post by kdmiller45 »
I just installed ZoneMinder and went to my ip 192.168.1.59/zm and got "User Authentication is not turned on" what file do I need to edit and where is the command to turn it on
Installed on Ubuntu 18.04
Installed per these instructions https://zoneminder.readthedocs.io/en/st ... buntu.html
Keith
Re: User Authentication is not turned on
I havn't been able to figure out who or what is redirecting to the login page but now it will automatically redirect from the login page to the console.
So give the latest a try. In the meantime just remove the view=login from the url
kdmiller45
I don't even get that far. This is what I see, view attachment
Yes that is the login view.
