appearance of "400 bad request" error after last update
alabamatoy
Post by alabamatoy »
Most recent update to 1.34.23 seems to have changed something causing the following error across all my cameras:
Mar 21 08:25:11 [servername] zmcontrol_17[21446]: ERR [Failed to get http://[login]:[password]@10.1.1.173/cgi-bin/ptz.cgi 400 Bad Request]
Any thoughts?
Re: appearance of "400 bad request" error after last update
There were no changes to the Amcrest PTZ scripts between 1.34.22 and 1.34.23.
Don't you run with some custom changes? Perhaps they got overwritten.
alabamatoy
iconnor wrote: Mon Mar 22, 2021 1:06 pm There were no changes to the Amcrest PTZ scripts between 1.34.22 and 1.34.23.
Hmm....your memory is much better than mine. I will investigate. Thx
