Access Token life time
WvdAkker
Post by WvdAkker »
I am lost ...
Thought the access token lifetime is 2 hours (AUTH_HASH_TTL = 2hrs in the option list).
However, last evening at 19:52 I created an access token. It shows it should expire at 21:52.
With the token I added a life stream om my website expecting this would stop at 21:52.
The stream continues after 21:52. Also stopping starting webbrowser did not had any effect.
The stream continues to show with the old (expired ?) token.
I use <img src="https://server/zm/cgi-bin/nph-zms?scale ... ken=<token>" />
for the stream.
After 13 hours I can still access the camera with the old access token.
Do I miss something about the lifetime of the access token?
Re: Access Token life time
the zms streaming cgi won't constantly check the validity of the token. Only at the start of the request. So once a stream starts it will go forever.
Perhaps we should fix that.
WvdAkker
Post by WvdAkker »
Ah ok.
What is considered start of the stream?
'Endless time' for an access token is for a website the easiest to maintain.
However from security point of view it is not desirable, I guess and the
zms streaming cgi should check if the token is not expired.
I will create an issue for it and see if it make sense.
