Dual Lens Camera
mgarskey
Dual Lens Camera
Post by mgarskey »
I am wondering if any has setup a Dual Lens camera before? I am working with a Axis P3715 camera, which is a dual lens camera and I am only getting feed from camera 1.
The source of the camera is rtsp://cameraview:t000r@X.X.X.X:554/axis-media/media.amp and the method is TCP and source is type is FFmpeg.
When looking view from zoneminder itself I can only see camera 1, with no option to switch to camera 2 or get that feed as well.
I have also setup event triggering on both camera but still only get them for camera 1.
Has anyone had any success with type of camera setup before?
burger
Re: Dual Lens Camera
Post by burger »
I checked but the user manual doesn't detail the path...
You can view the feed from the cameras webpage right? Usually if you right click the feed to view in a new window it's /mjpg/video.mjpg. What if you right click and open the 2nd feed in a new tab?
Also sometimes it will announce a path when it boots via wireshark/tcpdump.
Oh, see if they use the same format they did for an old video encoder, e.g.
/mjpg/2/video.mjpg
fastest way to test streams:
mgarskey
Post by mgarskey »
I found a solution to the problem. I created two entries for the camera, one for each view and using the FFmpeg as the source type, I just need to add ?camera=2 at the end for the second view, for example;
rtsp://cameraview:t000r@X.X.X.X:554/axis-media/media.amp?camera=2
