Debian Repo Distribution
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
benjobeast
Post by benjobeast »
I installed following the documented instructions for Debian Stretch. I then noticed that this installed v1.32.3 is there a link somewhere to when the repo version will be updated to 1.34?
https://zmrepo.zoneminder.com/debian/release/stretch/
Re: Debian Repo Distribution
We create a new repo for each major version. You need to use {url]https://zmrepo.zoneminder.com/debian/re ... 4/stretch/[/url]
benjobeast
Thank you! I will use that.
benjobeast
So I have put
deb https://zmrepo.zoneminder.com/debian/release-1.34 stretch
into my sources.list and I am getting an error saying
E: Malformed entry 16 in list file /etc/apt/sources.list (Component)
needs a trailing /
benjobeast
I actually did try that too no luck.
benjobeast
Correction, I misunderstood which trailing slash I was missing. I thought it was after release-1.34, you meant after stretch. Thank you for the help!
nik282000
Post by nik282000 »
Just wanted to pop in and say thanks to iconnor. I've used ZoneMinder on Debian for about a year and a half now and it is awesome.
