Tried ZoneMinder back in 2012.
Trying again now with a new Security Camera.
1st thing is to install an Ubuntu server onto my Hypervisor server.
ZoneMinder install guide https://zoneminder.readthedocs.io/en/la ... -04-bionic only mentions 18.04?
Will ZM work with Ubuntu 20.10?
- bkjaya1952
Re: Will ZM work with Ubuntu 20.10?
You can install Docker Zoneminder on Ubuntu 20.10.
Please refer the following links for the installation details.
https://hub.docker.com/r/bkjaya1952/doc ... 7.4-mysql8
https://hub.docker.com/r/bkjaya1952/zon ... ker-latest
Ubuntu guides are here:
https://wiki.zoneminder.com/Ubuntu
Specifically:
https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.34.x
Trying anything not covered there, you are on your own.
Specifically:
fastest way to test streams:
- bkjaya1952
Please refer the following link to see how zoneminder master latest is installed on Ubuntu 20.10 (groove)
https://bkjaya.wordpress.com/2021/01/02 ... 10-groovy/
In this case zoneminder master 1.35.16~20201227195743-focal is installed on Ubuntu 20.10 (groove) as zoneminder master 1.35.16~20201227195743-groovy has some problem on Dependency wait on lgw01-amd64-002
After the official lgw01-amd64-002 is issued , you can directly install zoneminder master 1.35.16~20201227195743-groovy on Ubuntu 20.10
I don't recommend installing 1.35 (unstable) Zoneminder. New users should install the stable release on Zoneminder only (1.34, i.e. even numbers).bkjaya1952 wrote: ↑Fri Jan 01, 2021 7:12 pm Please refer the following link to see how zoneminder master latest is installed on Ubuntu 20.10 (groove)
- bkjaya1952
Zoneminder masater releases are for testing purpose . How can you test without installing ? I have just answered the question in the original post.burger wrote: ↑Fri Jan 01, 2021 9:51 pmI don't recommend installing 1.35 (unstable) Zoneminder. New users should install the stable release on Zoneminder only (1.34, i.e. even numbers).bkjaya1952 wrote: ↑Fri Jan 01, 2021 7:12 pm Please refer the following link to see how zoneminder master latest is installed on Ubuntu 20.10 (groove)
I wanted to show that the Zoneminder can be installed on Ubuntu 20.10 . No one can discourage me in doing experiments with Zoneminder
