flat css error
alabamatoy
flat css error
Post by alabamatoy »
Getting lots of errors like the following:
 2020-12-24 14:13:19	web_php		2206	ERR	Invalid skin css 'flat' setting to base	/usr/share/zoneminder/www/index.php	116
The line it references is the error message, which really doesnt help much. I have searched and there are several threads about this issue, but they all seem to be much older versions than 1.34
Any suggestions?
alabamatoy
Re: flat css error
I have selected every possible option display and config settingsd related to CSS, and saved and restarted, same thing, log is filled with the flat error.
Re: flat css error
You need to select it in options -> Display
alabamatoy
Re: flat css error
iconnor wrote: Fri Dec 25, 2020 6:34 pm You need to select it in options -> Display
I have selected every possible alternative in the "display" window, saved, and restarted ZM. Error persists. Even rebooted the OS as well, same thing.
alabamatoy
Re: flat css error
I believe I discovered the cause of this error. The "flat" CSS is read from a cookie. If you carry over a cookie from a previous version of ZM, you get this error, apparently there is some stuff in the cookie that wont work with the new version.
Deleting all the cookies for the site eliminated the nonstop stream of errors in the log.
This might be a worthwhile addition to the upgrade instructions, to delete all cookies for the site in your browser during the upgrade. Or perhaps, if this error is encountered, force deletion and reset of the cookie in the code.
