1.35.13~20201104164822-focal
No camera streams. Previously recorded functions seem OK.
Screenshot from 2020-11-04 15-12-42.png (283.24 KiB) Viewed 1289 times
Re: 1.35.13~20201104164822-focal
Now 1.35.13~20201104182816-focal -same.
.../zmpkg.pl start exits exception staus 255
There are issues. The inital db update script didn't work on mysql 5.7, only 8. So you may need to update and manually re-run the update.
mysql -u zmuser -p zm < /usr/share/db/zoneminder/zm_update-1.35.13.sql
I may have to do a .14 with the changes, just waiting to find out what else I've missed.
bkjaya1952
Post by bkjaya1952 »
Today I have tested Zoneminder-master 1.35.13~20201104182816-focal with a USB camera monitor .
1.No problem in creating the USB monitor.
2. Emailing and uploading motion detection events are OK
3. Brightness settings of the monitor didn't work
4. some errors are visible in the logs ( Pl see the attached images)
Screenshot from 2020-11-05 13-01-12.png (338.18 KiB) Viewed 1223 times
Screenshot from 2020-11-05 12-52-04.png (337.5 KiB) Viewed 1223 times
Screenshot from 2020-11-05 12-52-37.png (366.83 KiB) Viewed 1223 times
