Anpviz Cam in ZoneMinder
___elvis___
Post by ___elvis___ »
I have installed several Anpviz 5MP IPCam (https://amzn.to/3mL4w43) and want to manage them in ZoneMinder.
Unfortunately I do not get them displayed. In the own web interface everything works.
I have done the following:
Source type: ffmpeg
Function: Monitor
Quellenpfad: rtsp://admin:123456@192.168.178.15:1935/cam/realmonitor?channel=1&subtype=0
Remote Method: tcp
Color: 32bit
Resolution: 1920x1080
RTMP is enabled in the camera settings and port 1935 is preset.
Please help me to set up the Anpviz 5MP IPCam in ZoneMinder.
Thank you.
Translated with www.DeepL.com/Translator (free version)
Re: Anpviz Cam in ZoneMinder
You are using RTSP, not RTMP. Test using VLC or similar.
Maximo1970
Post by Maximo1970 »
I've a got a few of these cameras. You'll need to make sure you have configured the camera via it's own web interface. Under the Network configuration section, got the subsection service ports and make that for RSTP there is no tick in the Authentication checkbox.
But once you've done, all you need to do is add the following to the Source Path of the monitor: rtsp://IPADDRESS/h264_stream0
You should be go to go from there.
