Raspberry PI cam setup (local, on board with the zoneminder install)
mlw19mlw91
Post by mlw19mlw91 »
Hey guys, I have zone minder on a raspberry pi 4b with the rpi cam and I can not figure out how to access it. I've tried a few things but nothing works. Please help! What's the path? What's the caputre mentod? Is it local, as far as the source type goes?
I promise I'll put this in the WIKI after :)
burger
Re: Raspberry PI cam setup (local, on board with the zoneminder install)
Post by burger »
General RPI info is covered in wiki.zoneminder.com/Single_Board_Computers
For the camera, there are numerous guides online that cover setup. Did you search?
https://raspberrypi.stackexchange.com/q ... tion#26386
I recommend you test in ffmpeg or vlc first (probably ffmpeg, since you shouldn't have X on the RPI). e.g.
ffmpeg -i /dev/video0  output.mp4
If it's /dev/video0 it would be local. You will need to know the resolution (ffmpeg will tell you this).
fastest way to test streams:
