log not filter
Cramac1
log not filter
Post by Cramac1 »
Hello. Install 1.35.6
filter stopped working in logs
Re: log not filter
Just pushed a fix. packages building.
bkjaya1952
Re: log not filter
Post by bkjaya1952 »
iconnor wrote: Wed Sep 16, 2020 2:09 pm Just pushed a fix. packages building.
Yes ! The fix is working in Zoneminder master 1.35.6~20200916100837-focal
ovargaspcr
Re: log not filter
Post by ovargaspcr »
It did fixed the problem with the log filters, but I don't know if it's just me but now I have problems if I try to delete a zone on any of the monitors. Delete option is not working at all.
Re: log not filter
delete zone is fixed
ovargaspcr
Re: log not filter
Thanks iconor, I'm still unable to delete zones with the latest package version. Deleted and reinstalled zoneminder and didn't fix it. So I allowed myself (hope you don't mind) to look at the code of the version I've installed (I used to code a long long time ago and not on php) and did little
zones.txt
had to rename it to txt, doesn allow to attach php files, original lines are commented out next to the lines that I changed.
(1.92 KiB) Downloaded 169 times
changes to it. It seems to be working on my installation for the little testing I did (by pure luck). I'm not sure again if it's the latest version that I'm using, but this is what I did to the /includes/actions/zones.php file (attachment)
regards
Ovargasp
Re: log not filter
yeah that's not based on today's code.
We are no longer concerned with mid, only zid... gettid?
Instead of looking at what packages are available you might want to follow commits on github. Prepare to marvel at the brevity of our commit messages!
Keep testing. Things will smooth out soon I'm sure.. or we will break them REALLY GOOD!
ovargaspcr
Re: log not filter
OK I'll do that, thanks again for your help.
regards
Ovargasp
Cramac1
Re: log not filter
Post by Cramac1 »
log update is not convenient. I do not have time to set the filter, as the page is refreshed.
