Released 1.34.19 My Friend Of Misery
# Changes since 1.34.18
- Handle backticks in matches sort fields. Fixes regression in 1.34.17
- Fix MOCORD not going into alarm state.
- rough in devuan beowulf support
- fix zms urls not including scale parameter value Fixes #3011
- improvements to the shutdown popup warning of missing shutdown executable config
- use just hostname in CSP headers so that multiple ports are supported in multi-server
- fix layout on zone editing Fixes #2961
- fix inline js CSP violation on zones
- only commit event DiskSpace when the event is complete. See #3007
1.34.19
Full Changelog
tagaroni
Re: Released 1.34.19 My Friend Of Misery
Post by tagaroni »
How can I get it? RPM Fusion is still at 1.34.18.
bigdigiman
Post by bigdigiman »
I too am only finding the 1.34.18 RPM on RPM Fusion and am in need of 1.34.19 as well...
tagaroni
Post by tagaroni »
If you're still looking you can find 1.34.20-2 here: http://koji.rpmfusion.org/koji/packagei ... kageID=501.
I had to download the rpms and install locally.
