Unable to connect to ZM db.could not find driver [Debian buster]
fromillo
Post by fromillo »
i've tried to install zoneminder on ubuntu buster
It seems to be installed, but after some updates (of debian) i have this message when i try to connecto to it:
Do you have any idea?
Thank you very much
Re: Unable to connect to ZM db.could not find driver [Debian buster]
What install instructions did you use?
And, Buster is a Debian distro. Ubuntu is not. Maybe you should give us more info about your hardware and double check which version of Linux you use.
Edit:
This may be your problem: viewtopic.php?f=40&t=29774
You may have two copies of PHP or some parts of an old version left.
fromillo
Post by fromillo »
Yes, you're right.
I'm using Debian (i dont know why i wrote ubuntu :) ) buster
I don't remeber since i'm using zoneminder from some years, and i upgrade Debian after some months every releases came out.
I follow your link. Ok maybe i've more php installed, but i've no idea how to solve. In that post they didn't write how they solved.
Thank you and best regards
burger
Post by burger »
If you are using apache, it's handled by an apache command.
a2enmod
or
a2dismod.
Disable the old php (e.g. a2dismod php7.0)
and enable the new one. You can find version numbers in /etc/php.
fastest way to test streams:
fromillo
Post by fromillo »
Thank you everyone.
Searching the forum, and with your comments and suggestions, i fixed the problem.
I write how to fix it (on my debian buster).
I simply removed apache, sql (mariadb) and zoneminder with purge options in apt.
Then i re-installed them with apt install
Now it works, maybe something didn't worked properly during updates.
Thank you very much
