Timestamp Video File
pdrhm
Post by pdrhm »
Hey Guys,
I'm using Zm 1.34.16 and all video files are used to Object Detect and Face Recognition by my algorithms in other machine!
The problem is: I populate my MySQL database with the time i found the person in scene, to do it i need to get the timestamp of the Video File (start or end).
With this in hands, i can use to know dates with more person in my front street.
Now the events are saved in this incremental way: monitor/Date/event+1/event+1.mp4
For Monitor 1 -> 1/2020-06-16/1/1.mp4...1/2020-06-16/44/44.mp4, etc.
Two questions:
- Can i change the monitor name that include changing folder name? I have only one and the folder is "1", if i add another this will be "2". If i can change for example: FrontDoor, BackDoor
- Can i change the way that events are stored? Folder or video file named with timestamp
Thanks!
burger
Re: Timestamp Video File
Post by burger »
pdrhm wrote: Tue Jul 21, 2020 8:29 pm - Can i change the monitor name that include changing folder name? I have only one and the folder is "1", if i add another this will be "2". If i can change for example: FrontDoor, BackDoor
The monitor name is the folder name. I'm not sure what you are asking with #1. Do you want to know if you change the monitor name, will the folder name change? You can always use a symbolic link / alias, if you want different names.
For #2, It's FOSS, so you can change anything. I don't think this can be handled via GUI though.
fastest way to test streams:
