Zoneminder 1.34.15 keeps deleting events before hitting 95% disk full
ebeng
Post by ebeng »
Hi all,
I am using the following script in viewtopic.php?f=9&t=27537&p=115886#p115886 to capture the video.
I am running now Zoneminder 1.34.15
For these events which are created by this script, are automatically deleted after 1 whole day.
The events which are created by Zoneminder itself, are not deleted after 1 whole day.
As you can see also in the logs here below, these events are deleted by www-data and not the root, which is running with ROOT user.
ubuntu@zoneminder_v18:~$ grep 323704 /var/log/audit/audit.log
type=PATH msg=audit(1592224034.271:1651): item=0 name="/var/cache/zoneminder/events/1/2020-06-14/323704/" inode=46923778 dev=fd:00 mode=040755 ouid=33 ogid=33 rdev=00:00 nametype=NORMAL cap_fp=0000000000000000 cap_fi=0000000000000000 cap_fe=0 cap_fver=0
type=PATH msg=audit(1592224034.271:1652): item=0 name="/var/cache/zoneminder/events/1/2020-06-14/323704/" inode=46923778 dev=fd:00 mode=040755 ouid=33 ogid=33 rdev=00:00 nametype=NORMAL cap_fp=0000000000000000 cap_fi=0000000000000000 cap_fe=0 cap_fver=0
type=PATH msg=audit(1592224073.251:1687): item=0 name="/var/cache/zoneminder/events/1/2020-06-14/323704/" inode=46923778 dev=fd:00 mode=040755 ouid=33 ogid=33 rdev=00:00 nametype=NORMAL cap_fp=0000000000000000 cap_fi=0000000000000000 cap_fe=0 cap_fver=0
type=PATH msg=audit(1592224073.255:1688): item=0 name="/var/cache/zoneminder/events/1/2020-06-14/323704/" inode=46923778 dev=fd:00 mode=040755 ouid=33 ogid=33 rdev=00:00 nametype=NORMAL cap_fp=0000000000000000 cap_fi=0000000000000000 cap_fe=0 cap_fver=0
type=PATH msg=audit(1592224549.018:1725): item=0 name="/var/cache/zoneminder/events/1/2020-06-14/323704" inode=46923778 dev=fd:00 mode=040755 ouid=33 ogid=33 rdev=00:00 nametype=NORMAL cap_fp=0000000000000000 cap_fi=0000000000000000 cap_fe=0 cap_fver=0
type=PATH msg=audit(1592224549.018:1726): item=0 name="/var/cache/zoneminder/events/1/2020-06-14/323704" inode=46923778 dev=fd:00 mode=040755 ouid=33 ogid=33 rdev=00:00 nametype=NORMAL cap_fp=0000000000000000 cap_fi=0000000000000000 cap_fe=0 cap_fver=0
type=CONFIG_CHANGE msg=audit(1592224549.018:1727): auid=4294967295 ses=4294967295 op=updated_rules path="/var/cache/zoneminder/events/1/2020-06-14/323704/323704-video.mp4" key=(null) list=4 res=1
type=PATH msg=audit(1592224549.018:1728): item=1 name="323704-video.mp4" inode=13505121 dev=fd:00 mode=0100644 ouid=33 ogid=33 rdev=00:00 nametype=DELETE cap_fp=0000000000000000 cap_fi=0000000000000000 cap_fe=0 cap_fver=0
type=CONFIG_CHANGE msg=audit(1592224549.134:1729): auid=4294967295 ses=4294967295 op=remove_rule path="/var/cache/zoneminder/events/1/2020-06-14/323704/323704-video.mp4" key=(null) list=4 res=1
type=PATH msg=audit(1592224549.126:1730): item=1 name="/var/cache/zoneminder/events/1/2020-06-14/323704" inode=46923778 dev=fd:00 mode=040755 ouid=33 ogid=33 rdev=00:00 nametype=DELETE cap_fp=0000000000000000 cap_fi=0000000000000000 cap_fe=0 cap_fver=0
ubuntu@zoneminder_v18:~$ id -u www-data
33
trending_up Load: 4.75 storage DB:19/151 Storage: Default: 13% /dev/shm: 39%
Re: Zoneminder 1.34.15 keeps deleting events before hitting 95% disk full
there are 3 places that do deletes
#1 a filter. Filters run as www-data
#2 zmaudit.pl. You should not be running this anymore. Check options->SYstem->ZM_AUDIT. Turn it off. This is the likely culprit.
#3 someone using the web interface to delete the events. This seems unlikely.
ebeng
Post by ebeng »
iconnor wrote: Mon Jun 15, 2020 6:52 pm there are 3 places that do deletes
Do you mean:
RUN_AUDIT  : Run zmaudit to check data consistency (?)
ebeng
Post by ebeng »
Only 'unchecking' the ZMAUDIT is not helping, you have to restart the Zoneminder also :)
This was indeed the one, which was deleting it. My events are now filling up with the recordings, without being deleted!! :)
Thank you !!
