All events are being deleted after restarting docker
serveit
Post by serveit »
Whenever I stop and start the Zoneminder Docker, I can't view the events that were recorded before stopping. It shows a black screen with an X in the middle and this error message.
Recording path: /var/cache/zoneminder/events
Error Message: The video could not be loaded, either because the server or network failed or because the format is not supported.
I'm using Ubuntu 20.04 LTS & Nginx.
I have given www-data permission.
Docker: dlandon/zoneminder
burger
Re: All events are being deleted after restarting docker
Post by burger »
Post the docker command or docker-compose.yml
I'd advise using docker-compose.yml
(this should be moved to docker forum)
fastest way to test streams:
