[Solved]Why is this filter rule not working?
Bluemax
Post by Bluemax »
Why is this filter rule not working? I can press 'execute' and i see a properly processed event list (corresponding entries are removed) but when i go to 'console' all events are still there. Other rules like 'purge' or another 'Total Score' rule (without time) do work properly. Its running for hours. The rule doesn't get applied automatically.
Re: Why is this filter rule not working?
I would need to see debug logs showing the sql, and a listing of events that should match it.
Bluemax
Post by Bluemax »
Thanks, but it works now. I've set my database some days back (actually i forgot to save it :wink:) and re-created the filter (with some minor differences) and now it works (its disabled on the screenshot atm). I also had some leftover files from a previous ZM session that were not registered in the active database that i've cleaned as well. So, i'm not really sure why it didn't work before.
