camera checked even it was disabled
harry491
Post by harry491 »
check LOGs and found frequent "failed contact requests" to camera which are marked as "Modect, disable".
Is this a correct behavior? Continue even camera has been disabled?
Now I changed the function to "none" - silence.
Greetings
Harry491
Re: camera checked even it was disabled
the disabled means that motion detection isn't happening. It is still capturing.
You have to change the function to none.
