delete montage layouts
sh4q
Post by sh4q »
Hello everybody,
my zoneminder 1.35.5 installation is running fine.
I have only one problem. How can i delete created montage layouts in the montage tab? I only have a save and abort button.
Thanks in advcance!
Re: delete montage layouts
At the moment you will have to use sql commands to delete the rows in the Montage_Layouts table.
I will take a look at adding a delete button in 1.34.8
basketcase
Post by basketcase »
Thanks for that answer.
On 1.34.9 I'd noticed a couple of funny issues with monitors being outside of visual range and one which is actually double it's true size mirrored above itself ( flipped above on the x axis, though invisible, but clickable), it's invisible boarder appears when you click 'show zones'. It overlays anything above it so easy to accidentally click if the monitor is below any controls.
I simply moved it to the right, where the effect has no impact.
I'm happy though, this response guided me to the DB and table to find the positions data and bring back my missing monitor. Now it's looking perfect. Thanks again!
