Tutorial Zoneminder with platerecognition
biologisch
Post by biologisch »
Here is a new tutorial for a fast installation of zoneminder with platerecognition
https://zoneminder.miraheze.org
ZM Versions = 1.36.33
zmeventnotification Version = "6.1.28"
Re: Tutorial Zoneminder with platerecognition
very cool...
asker
Post by asker »
biologisch wrote: Wed Feb 26, 2020 10:56 am Here is a new tutorial for a fast installation of zoneminder with platerecognition
Thanks for the exhaustive tutorial!
Two notes:
1. You only need to install the contrib package of OpenCV. It includes base OpenCV.
2. If you use 127.0.0.1 for your picture url it will not show on phones.
Please read before posting:
ES docs
zmNinja docs
biologisch
Thanks for your support. :D
fixed - thank you again.
? Everything works fine - also on phones. Is it better to take http://localhost or the server IP ?
A couple of corrections to your Zoneminder install procedure...
Your procedure adds the ppa but does not install Zoneminder.
sudo apt-get update is not needed in Bionic as add-apt-repository does this.
apt install zoneminder is needed!
sudo systemctl enable zoneminder.service should be: sudo systemctl enable zoneminder
sudo systemctl start zoneminder.service not needed as the installer starts Zoneminder
sudo a2enmod cgi is not needed as the Zoneminder installer does this.
Set your correct timezone in /etc/php/7.2/apache2/php.ini is not needed as the timezone is now set in Zoneminder Options
sudo chown -R www-data:www-data /usr/share/zoneminder/ DO NOT DO THIS! Security risk and is not needed!!!
See: https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.34.x
biologisch
Correct! Fixed.
systemctl show zoneminder | grep Path
gives
FragmentPath=/lib/systemd/system/zoneminder.service
back. So both variants are possible.
Correct! Fixed.
Correct! Fixed.
Correct! Fixed.
Correct! Fixed.
Thank you for taking your time and help me to make the tutorial better.
Are suggestions are very welcome!
Thanks for the useful tutorial. Being able to restrict ANPR to just the road area was helpful.
