I need some guidance on figuring something out on our Zoneminder web page on the console tab.
Under the *Function* column it usually says Record and then it says Capturing underneath.
At some point (I'm unsure when) it now says Unknown instead for Capturing (picture attached).
I'm able to view events, so it seems to be recording. There's also no error's in the log that I can see.
I've looked through the forum and still searching the internet, but cannot find anything on this yet. Has anyone else experienced this before?
Zoneminder version: 1.32.3 on Ubuntu 18.04.3
Cameras: Hikvision DS-2DE2A404IW-DE3 (PTZ) and DS-2CD2123G0-I
Monitor Settings: Source Type Ffmpeg, Function Record, Storage H264 Passthrough
All 3 cameras are set to 1920x1080 and 10 FPS.
Kind regards,
pennyzm
Edit: Looking through the documentation again, specifically in the *Getting Started* section, there's mention of the Visual Filter which is on the Console page. I noticed in the visual filter section on our Zoneminder server the *Status* filter and it does list *Unknown* as an option. So I can filter between Unknown, Capturing, etc. However it's still not clear to me what Unknown means. I'll keep looking, but if anyone can help explain please do.
Function Column shows Record/unknown
- zoneminder_function_column.jpg (24.64 KiB) Viewed 7940 times
Re: Function Column shows Record/unknown
i have same problem, but currently not really solve.
u can change setting on "Source" column, n then on tab Source change base on your camera,
below is example base on my camera
- zonminder fixing error.png (13.38 KiB) Viewed 5511 times
@cakteguh, thank you for your reply and help.
The issue went away for me once I updated to zoneminder 1.34.2.
I've not seen it since. My apologies for not posting sooner, I had forgotten to come back and share it.
Kind regards,
pennyzm
Kind regards,
pennyzm
