Only one camera capturing, audio stream
jasiekk
Post by jasiekk »
Hello!
I have ubuntu 18.04 with zoneminder 1.34.0. When i go to console, there always is only one monitor "capturing" and two other are "not capturing" (I am using webcams). When i add only one it works perfectly (with all of them).
1. How can i use few webcams/cameras at the same time?
2. How can i stream audio (i don't need to record it, but it'll be nice)
Re: Only one camera capturing, audio stream
Per your source you are using local cams not webcams.
jasiekk
Post by jasiekk »
So i can't use webcams?
webcams are fine, they present as local.
Your Logs is red. Have you thought to look there for the reason?
Audio is not supported with local cams at this time. Should happen sometime in 1.35
jasiekk
Post by jasiekk »
Yes, I saw they're red, but i don't know what can I do.
And about audio, can i use other program to stream it?
