[solved] Fail to start after ugprade from 1.32
lbm
Post by lbm »
I've upgraded from 1.32 to 1.33 from the master repo.
Then ran . zmupdate.pl to update schema changes, etc..
No other changes was done.
But im now unable to start zoneminder.
If I just trie with the binary, I get.:
zmpkg.pl start
01/16/2020 16:29:56.314070 zmpkg[9087].INF [main:310] [Sanity checking States table...]
01/16/2020 16:29:56.315263 zmpkg[9087].INF [main:95] [Command: start]
01/16/2020 16:29:56.395417 zmsystemctl[9093].INF [main:71] [Redirecting command through systemctl]
Job for zoneminder.service failed because the service did not take the steps required by its unit configuration.
See "systemctl status zoneminder.service" and "journalctl -xe" for details.
And in the log...
Jan 16 16:32:43 zoneminder systemd[1]: session-c427.scope: Succeeded.
Jan 16 16:32:43 zoneminder systemd[1]: zoneminder.service: New main PID 10310 does not belong to service, and PID file is not owned by root. Refusing.
Jan 16 16:32:43 zoneminder systemd[1]: zoneminder.service: Failed with result 'protocol'.
Jan 16 16:32:43 zoneminder systemd[1]: Failed to start ZoneMinder CCTV recording and surveillance system.
Jan 16 16:32:45 zoneminder systemd[1]: Stopped ZoneMinder CCTV recording and surveillance system.
lbm
Re: Fail to start after ugprade from 1.32
Post by lbm »
Ok. So the "/lib/systemd/system/zoneminder.service" had
#User=www-data
Changed it to:
User=www-data
Can now, start but now it keeps crashing..
Jan 16 16:45:08 zoneminder zmdc[11048]: INF [Starting pending process, zmc -m 5]
Jan 16 16:45:08 zoneminder zmdc[11145]: INF ['zmc -m 5' started at 20/01/16 16:45:08]
Jan 16 16:45:08 zoneminder zmdc[11048]: INF ['zmc -m 5' starting at 20/01/16 16:45:08, pid = 11145]
Jan 16 16:45:08 zoneminder zmdc[11048]: INF ['zmc -m 18' crashed, signal 6]
Jan 16 16:45:08 zoneminder zmc_m5[11145]: INF [zmc_m5] [Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor not part of your debug targets]
Jan 16 16:45:09 zoneminder zmdc[11048]: INF ['zmc -m 5' crashed, signal 6]
Linux distro and version?
lbm
Post by lbm »
Sorry.
Its Debian 10 buster, with zm: 1.33.16~20191225.23-buster
In the zm web interface, I've got the following errors:
Date/Time
Component	Server	PID	Level	Message	File	Line
2020-01-16 20:53:11	zma_m18		1834	ERR	Shared data not initialised by capture daemon for monitor Backyard_Modetect	zm_monitor.cpp	498
2020-01-16 20:53:11	zmdc		1219	ERR	'zma -m 18' exited abnormally, exit status 255	zmdc.pl
2020-01-16 20:53:11	zma_m18		1833	ERR	Shared data not initialised by capture daemon for monitor Backyard_Modetect	zm_monitor.cpp	498
2020-01-16 20:53:10	zmdc		1219	ERR	'zma -m 5' exited abnormally, exit status 255	zmdc.pl
2020-01-16 20:53:10	zma_m5		1827	ERR	Shared data not initialised by capture daemon for monitor Entrance_Modect	zm_monitor.cpp	498
lbm
Post by lbm »
I've fixed it..
I've got these errors, at some point, and increased it to 1024:
ImageBufferCount 550 is too small. Needs to be at least 553. Either increase it or decrease time between keyframes
Tried to lower it, to 550, and now it works, but with the above error.
Increased it to 560, now error seems to be gone.
