Xiaomi Dafang
MrReview
Xiaomi Dafang
Post by MrReview »
Good evening,
I hope my first post will not get me kicked out of the forum ;-)
I googled for two days now but can’t find a solution :-(
I tried to connect to a Xiaomi Dafang cam (with dafang-hacks) and NO setting works. No matter what I set up, it’s always in “Not running” status.
When I use the same rtsp address in MotionEye, then it works within seconds. So I assume I’m doing sth wrong when setting up ZM?
I’m running ZM in a Docker container - version 1.32.3
Thanks,
MrReview
Re: Xiaomi Dafang
Get the camera working in VLC then use the same string in Zoneminder. Just check the reported resolution in VLC to use in Zoneminder.
Also, try Zoneminder without a container.
nychawk
Re: Xiaomi Dafang
Post by nychawk »
Have you gotten this working yet? If so, can you share your findings?
Thank you,
-mi
