zonmidner service is working - can't see video on remote computer?
david1234
Post by david1234 »
a strange issue
I have upgrade 1.30.0 to 1.30.4
didn't change any cameras\setting
now when I enter the zonminder - and try to see live video (which I was able to see yesterday) I get the page but no video , just a small icon
when I enter log
Date/Time
Component	Server	PID	Level	Message	File	Line
2019-12-25 10:27:36.193596	web_js		1742	ERR	getStreamCmdResponse stream error: Socket /var/run/zm/zms-587655s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()	?view=watch
2019-12-25 10:27:34.019425	zmc_m9		1574	INF	Door: 15000 - Capturing at 24.39 fps	zm_monitor.cpp	3125
2019-12-25 10:27:11.514153	web_php		1103	ERR	Socket /var/run/zm/zms-587655s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.	/usr/share/zoneminder/www/includes/functions.php	2033
2019-12-25 10:27:09.289048	web_php		1675	ERR	Socket /var/run/zm/zms-587655s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.	/usr/share/zoneminder/www/includes/functions.php	2033
2019-12-25 10:27:07.511392	web_php		572	ERR	Socket /var/run/zm/zms-587655s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make
what is change , and what I need to do to fix this?
Re: zonmidner service is working - can't see video on remote computer?
Check Options/Paths/PATH_ZMS should be /zm/cgi-bin/nph-zms
david1234
Post by david1234 »
it is ,
I check some otehr issues and it's seem that the SD is been corrupted - so I will reinstall everything
Thanks ,
